Point of intersection of two lines
The problem involves finding the point of intersection of two lines defined by parametric equations in three-dimensional space.
  • Exploratory, Assumption checking
  • The original poster attempts to set the equations equal to find a common parameter but encounters discrepancies in the values of t. Some participants suggest redefining the parameters for each line to facilitate the comparison.
The discussion has progressed with participants exploring the implications of using different parameters for each line. Guidance has been offered regarding the next steps after obtaining values for the parameters.
There is an indication of confusion regarding the relationship between the parameters of the two lines and how they relate to finding the intersection point.
dcramps
Find the point of intersection of two lines
x = -9 + 5t
y = 1 + t
z = 10 - 4t
and
x = -2 -3t
y = 5 + 2t
z = 5 + 3t
N/A
I have read that you should set two of the equations equal to find the value of t, and that value of t should hold for the third equation, but whenever I do that I get two different values for t, and neither of them hold up in the third equation. What am I doing wrong?
Hi dcramps! :smile:
Where the two lines intersect, the parameter t will be different on each line. :wink:
So call the parameter for the second line u, then set two of the equations equal to find the values of t and u. :smile:
Thanks! Now I have my t and u values, and plugging them into the third equation gives me equality...but where do I go from here? Do I plug them into all of the original equations and use the results as my intersection point?
Yup! :biggrin:
Excellent. Thanks for your help :)
  • · Replies 21 ·
