Calculating Height and Distance of a Mountain at Sea
  • MHB
  • Thread starter xyz_1965
  • Tags
    Points
In summary, the distances between points A and B on land at sea are 80 meters and 37 degrees. The mountain top is at an elevation of 41 degrees, which is 37 degrees less than the angle of elevation to the top of the mountain.
xyz_1965
76
From points A to B at sea, the angles of elevation to the top of the mountain T are 37 degrees and 41 degrees, respectively. The distance between points A to B is 80 meters.
1. Find height of the mountain.
2. Find the distance from point A to the bottom of the mountain.
I think making two triangles makes sense here.
Triangle 1
tan(41°) = h/x
Let h = height of mountain.
Let x = the distance from point B out at sea to the bottom of the mountain.
Solving for x, I get h/tan(41°).
Triangle 2
tan(37°) = h/[80 + (h/tan(41°)]
I need to solve triangle 2 for h, the height of the mountain. After finding h, I can then find the distance between point B out at sea and the bottom of the mountain.
Lastly, the distance from point A out at sea to the bottom of the mountain is found by adding A + B.
1. Is any of this right?
2. Is there an easy way to solve
tan(37°) = h/[80 + (h/tan(41°)] for h?
Mathematics news on Phys.org
assuming A, B, and the mountain top are located in the same vertical plane ...
$h = x_B \tan(41)$
$h = x_A \tan(37)$
$x_A - x_B = 80 \implies x_A = x_B +80$
$x_B \tan(41) = (x_B+80)\tan(37)$
$x_B = \dfrac{80\tan(37)}{\tan(41)-\tan(37)}$
from here, calculate $x_B$, add 80 to get $x_A$, and use either value in one of the original equations to find $h$.
$h = x_B \tan(41)$
$h = x_A \tan(37)$
Explain $x_B$ and $x_A$.
$x_B$ is the horizontal distance from point B to the point directly below the mountain top.
$x_A$ is the horizontal distance from point A to the point directly below the mountain top.
Thank you for clearing this up for me.
A few comments
Triangle 1
tan(41°) = h/x
It would make more sense to say these before you say "tan(41)= h/x!
Specifically, x= h/tan(41).
Triangle 2
I think I would have first said "Let y be the distance from B to the base of the mountain" to get tan(37)= h/y and then use y- x= 80 so that y= 80+ x but that becomes the same thing.
Yes.
No! You were doing so well and then you forgot how you had defined "A" and "B'! "A" and "B" are points, not distances so you can't add them. "x" was the distance from point A to the base of the mountain.
A= h/(B+h/C)
Get rid of the fraction by multiplying both sides by B+ h/C:
AB+ (A/C)h= h
AB= h- (A/C)h= Ch/C- Ah/C= (C- A)h/C
h= ABC/(C- A)
Of course A= tan(37°)= 0.7536, approximately, B= 80, and C= tan(41°)= 0.8693 approximately.
Country Boy said:
A few comments
It would make more sense to say these before you say "tan(41)= h/x!Specifically, x= h/tan(41).I think I would have first said "Let y be the distance from B to the base of the mountain" to get tan(37)= h/y and then use y- x= 80 so that y= 80+ x but that becomes the same thing. Yes. No! You were doing so well and then you forgot how you had defined "A" and "B'! "A" and "B" are points, not distances so you can't add them. "x" was the distance from point A to the base of the mountain.
A= h/(B+h/C)
AB+ (A/C)h= h
h= ABC/(C- A)
I thank you for the break down. It's ok to make mistakes here. Learning is not possible without errors.
That is true. And you learn by having those errors pointed out!
I agree. This is why I don't mind being corrected as long as it is done respectfully.
1. What are "Points A & B Out At Sea"?
"Points A & B Out At Sea" refers to two specific locations on the ocean, usually used as reference points for navigation or research purposes.
2. How are "Points A & B Out At Sea" determined?
The exact location of "Points A & B Out At Sea" can be determined using various methods, such as GPS coordinates, satellite imagery, or triangulation from known landmarks.
3. Why are "Points A & B Out At Sea" important?
"Points A & B Out At Sea" are important for navigation and research purposes. They can be used as reference points for ships and other vessels to determine their location and direction, and they can also be used for scientific studies and data collection in the ocean.
4. How far apart are "Points A & B Out At Sea"?
The distance between "Points A & B Out At Sea" can vary depending on their specific locations. They can be relatively close together or hundreds of miles apart, depending on their purpose and the area of the ocean they are located in.
5. Are there any other "Points" in the ocean besides "A & B Out At Sea"?
Yes, there are many other reference points and locations in the ocean, such as "Points C, D, and E". These points may also be used for navigation and research purposes, depending on their location and purpose.
  • General Math
  • Classical Physics
  • Earth Sciences
