Pointwise and uniform convergence of sequence of functions
The discussion revolves around determining the uniform convergence of a sequence of functions defined on the interval [0, 1]. The user initially finds it straightforward to show pointwise convergence to zero but struggles with uniform convergence. It is clarified that uniform convergence fails because the maximum of the function does not approach zero, specifically noting that for any n, there exists an x such that the function achieves a value of 1. The conversation emphasizes the need to compute the maximum values at critical points, concluding that since the maximum is greater than zero, uniform convergence is not achieved. The thread highlights the importance of understanding the behavior of the function as n varies.
Jncik
show if
has a uniform convergence of pointwise
also we know that x gets values from 0 to 1
for the pointwise I think its easy to show that limfn(x) as n->infinity is 0
but I am really stuck in uniform convergence
I know that fn converges uniformly to f if and only if for all ε>0 there is a natural number N so that for all n>=N |fn - f|<ε
if f(x) = 0
we get
now from this what can we do??
thanks in advance
So we have to decide whether
\sup\left|\frac{x^2}{(1-nx)^2+x^2}\right|\rightarrow 0.
To decide this, you'll need to calculate the maximum value of \left|\frac{x^2}{(1-nx)^2+x^2}\right|. And then you'll need to check whether this converges to 0 or not...
To calculate the maximum value, you'll have to do the usual: calculate the first derivative, see when it is 0, etc...
I guess it's really difficult to compute this by hand then...
it's really odd, my professor solves this in 3 lines but I'm 100% he's either wrong or doesn't explain the solution at all
he says that
for all n, there is a n0>n so that x0 = 1/n0
then he says
|fn0(x0) - f(x0)| = ... = 1
because of this we don't have uniform convergence...
i don't really understand it..
No, it's not difficult to compute by hand at all! You just need to find the maximum of the function...
And what your professor proposed is indeed correct, but he doesn't really give much details. Your professor claims that for every n, there is an x such that fn(x)=1. This implies that the maximum of the function fn is greater then 1! But then the maximum cannot converge to 0. This implies that there cannot be uniform convergence...
thanks I think I understand what he proposed now
but for the maximum of the function
i find that derivative is the following
[PLAIN]http://img24.imageshack.us/img24/9923/21098361.gif
for x = 0 it is 0
how can we figure out if the max is over 0?
for x = 0 it is 0
Well, you'll need to figure out when the expression above is 0. So, for what x, does
\frac{2x(nx-1)}{(n^2x^2-2nx+x^2+1)^2}=0.
This is equivalent to the question: for what x, does
2x(nx-1)=0...
well it's 0 for x = 0 and also it can be 0 for x = 1 and n = 1
but now I should figure out where's the max of the function
should I get values for x = -1, 0.5, 1.5 to find out what's the sign of f' or is there any other easier way?
for x = -1 I get -2*(n+1)/(n^2+2n+2)^2, because n is a natural this number is negative
for x = 0.5 I get (1-0.5n)/(0.25n^2-n+1.25)^2 and it depends on the n.. so i can't figure out if its positive or negative..
i ve never computed maximum of a function with n and x, our professor never showed us an example on this case and its really difficult for me to understand what's going on
No, that's not correct. Remember that n is a fixed value, you can't just set it to 1!
If 2x(nx-1)=0, then x=0 or nx-1=0. In this last case, we have x=1/n.
So for fn, we have the following possibilities for a maximum: 0 and 1/n. Now you will have to calculate both |fn(0)| and |fn(1/n)| to see which value is higher. This is the maximum of the function!
so because we get 0 and 1 and 1>0 this is the max, it would only converge if it was 0
thank you very much for your help, all I needed was a simple explanation like yours... thanks again :)
  • · Replies 18 ·
