Polariton Beams Provide Coherent Energy for 250x Less Power
Scientists have developed a polariton laser that operates using 250 times less power than traditional lasers, combining properties of both matter and light through polaritons, which are photon-electron-hole pairs. This energy efficiency could enhance applications in laser-sintering and electron-beam melting, particularly for high-temperature metals and high-resolution part shaping. However, there are questions regarding the practical pros and cons of integrating polariton beams into additive manufacturing. While polariton lasers may be beneficial for microelectronics due to their small size and low power, conventional lasers are likely to remain dominant in industrial applications requiring high power. The potential uses of polariton beams in spectrometry, LIDAR, and fusion energy are also being explored.
sanman
Scientists have developed a new type of laser, called a polariton laser, which can be generated using 250x less power:
http://www.eurekalert.org/pub_releases/2014-06/uom-anw060514.php
Polariton beams are said to have properties of both matter and light, since polaritons are a combination of a photon and an electron-hole pair. Could these unique properties provide benefits for a laser-sintering or electron-beam melting type of device?
After all, if energy-savings are involved, then that would be one way to improve performance. Furthermore, electron-beam melting is said to be useful for its very high energy levels, which allow it to melt higher-temperature metals, and to shape parts at high-resolution, since the heavier mass of the electron means its DeBroglie wavelength is lower.
What might be the pro's and cons of applying polariton beams towards additive manufacturing applications?
Likewise, could polariton beams be used for spectrometry, or LIDAR, or even fusion energy (a la NIF) for the benefit of these applications?
Science news on Phys.org
Lasers are generally pretty efficient. The little laser diode in your computer mouse, for example, is about 50% efficient in converting electrical energy into light energy. That's why your mouse does not heat up when you leave it on.
So I am quite certain a polariton laser is not 250x more efficient than a laser. I think it simply means that polariton lasers can be made a lot smaller and very low power, which may be useful in applications involving microelectronics.
Since industrial applications for lasers, such as very accurate cutting of materials, require very powerful lasers, I expect that conventional lasers will continue to be used.
AM
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
18K
