A Polarization of gauge bosons and gauge choice
spaghetti3451
Consider the following facts:
1. For a particle with momentum ##k##, the two transverse polarization vectors ##\epsilon({\bf k}, \lambda_{1})## and ##\epsilon({\bf k}, \lambda_{1})## are purely spatial and orthogonal to ##\bf k##, that is,
##\epsilon^{0}({\bf k}, \lambda_{1}) = 0,##
##\epsilon({\bf k}, \lambda_{1})\cdot{k} = 0,##
##\epsilon^{0}({\bf k}, \lambda_{2}) = 0,##
##\epsilon({\bf k}, \lambda_{2})\cdot{k} = 0.##
2. The third, longitudinal, polarization vector ##\epsilon({\bf k}, \lambda_{3})##}, for a particle with momentum ##k##, is timelike positive, orthogonal to ##k## as well as the transverse polarization vectors, and has unit negative norm, that is,
##\epsilon^{0}({\bf k}, \lambda_{3}) > 0,##
##\epsilon({\bf k}, \lambda_{3})\cdot{k} = 0,##
##\epsilon({\bf k}, \lambda_{3})\cdot{\epsilon({\bf k}}, \lambda_{1}) = 0,##
##\epsilon({\bf k}, \lambda_{3})\cdot{\epsilon({\bf k}}, \lambda_{2}) = 0,##
##\epsilon({\bf k}, \lambda_{3})\cdot{\epsilon({\bf k}}, \lambda_{3}) = -1.##
3. We can infer from the orthogonality of the polarization vectors that the longitudinal polarization vector of a particle points in the direction of momentum of the particle.
Are these facts true for any gauge choice of the electromagnetic four-vector ##A^{\mu}##?
Do you mean a photon with momentum ##k##? Your notation and your question seem to imply that.
There is a longitudinal polarization. This is for a W or Z boson.
But you refer to a gauge choice for the electromagnetic 4-vector. That's not the same as a W or Z boson. Which are you asking about?
In the electroweak standard model (as for any Higgsed gauge theory) the unitary gauge reveals the particle content explicitly. It's drawback is that the proper vertex functions are not explicitly renormalizable in this gauge, but to get the physical degrees of freedom, it's great. The great discovery by 't Hooft and Veltman in 1971 was thas one can choose a renormalizable gauge (called ##R_{\xi}## gauges), where the proper vertex functions are manifestly renormalizable since the power counting works as for scalar fields, i.e., the gauge-boson propogator falls qudratically with momentum in these gauges. Together with dim. reg. that enabled them to prove both the renormalizability of non-abelian Higgsed gauge theories and the unitarity and physicality of the S-matrix. It makes clear that both the Faddeev-Popov ghosts and the "would-be Goldstone bosons" conspire with the unphysical polarization degree of freedom of the gauge bosons to cancel these unphysical degrees out of the S-matrix (at any order in perturbation theory), and this makes the Standard Model a physically consistent QFT of the electroweak interaction.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
