How to Reduce Glare off Water by Factor of 1.33: Polarization Physics Problem
sachi
"by what factor may the glare off water be reduced when the sun is at
a) 45 degrees above the horizon
b)60 degrees above the horizon
n.b refractive index of water is 1.33"
I have derived the fresnel reflection coefficients for the cases when E is perpendicular to the plane of incidence, and when E is parallel to the plane of incidence. I am also assuming that "glare" is caused by the E-field. But I'm not sure which reflection coeffient to use i.e do we assume that E is parallel to plane of incidence of perp.?
thanks
The E field from the blue sky is predominantly horizontally polarized.
This is because the Rayleigh scattering polarizes the scattered radiation.
The horizontal polarization comes out to be
P=sin^2\theta/(1+cos\theta)^2.
You will have to use both E polarizations at the water surface.
The above factor gives the polarized horizontal E^2. Then you have to include both E polarizations with E^2 = one half of the unpolarized component.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
