Discover the Effects of Rotating Polarizing Films | Explained with Examples
  • Thread starter Thread starter Physics345
When two polarizing films are aligned with perpendicular orientations, light passing through the first film becomes polarized in that direction, but no light will pass through the second film due to the opposing polarization. The discussion highlights that when the films are rotated at various angles, the probability of light passing through the second film is determined by the cosine squared of the angle between the two films. This means that at 90 degrees, the probability is zero, resulting in complete blockage of light. The conversation also clarifies terminology, emphasizing that light does not "pass through" the second polarizer when aligned perpendicularly. Overall, the effects of rotating polarizing films demonstrate the fundamental principles of light polarization and interaction with polarizers.
Physics345
Imagine that you had two polarizing films and were holding them one on top of the other. what would be the effect of rotating the two polarizing films with respect to one another be? explain what would be seen and why.
none
Let’s say the first polarizer film was in the vertical direction, and the second was in the horizontal direction the light would go through the first vertical polarizer which would polarize the light in that direction, leaving 50% of the light. The remaining 50% vibrating light waves would be negated when they pass through the second polarizer. This would be the same scenario vice versa.
Uh ... "negated when they pass through the second polarizer"? Don't you mean "they would be blocked when they TRIED to pass through the second polarizer?"
Also, that is just one highly specific case. What happens when you rotate at other angles?
My textbook says negated, could it be wrong?
Also what other angles are we referring to?
Negated is not so much the problem as is the statement "they pass through the second polarizer" The point is they do NOT pass through the second polarizer when it is perpendicular to the first.
ALL other angles
ALL other angles
Why wouldn't they? What exactly is stopping them from passing through the second polarizer?
A polarizing filter effectively poses a question to the photon: are you polarized with me or against me? Simple binary choice. If with me you can go through, if against you can't.
Suppose there are two filters at angle θ. If a photon has got through the first filter it has committed to being polarized in that specific durection. When it has to decide at the second filter, its probability of saying "with" is cos2(θ). Thus, if they are at right angles, its probability of getting through the second filter is zero.
Likes Physics345
Sorry I'm so late with my reply. I re arranged my answer I'm pretty sure I got it now. Have a loo
k
Polarized light; is light whose electric fields are only oscillating in one direction. When un-polarized light whose electric field oscillates in any directions passes through a polarizer, the light becomes polarized. When light passes through the first polarized film, the lights electric field will oscillate in that direction. When they pass through the second polarized film which is perpendicular the remaining electric fields will be blocked, causing there to be no light left at all. Since the two polarized films are rotating perpendicular. Therefore we know regardless of the perpendicular rotation of the two films all light will be blocked off once it reaches the second perpendicular polarized film at all angles.
Physics345 said:
once it passes through
Except, it doesn't pass through.
Opps sorry that was a typo I didn't notice that. Other than that, do I have a proper understanding now?
I edited it to "reaches the second polarized film"
Make that "many directions" and your answer will be fine.
Likes Physics345
Done thank you both for your help!
