Pole Dance & Physics: Understand Momentum & Gravity
In summary, centrifugal force is what makes a person spin faster, but the fact that they are closer to the pole also makes it easier to spin.
LaurenAsh
Hi there
I would like to know about the physics involved in pole dance. for instance, why does more momentum make it easier to stay high on the pole and spin for longer? and how does this influence the effect of force on your body by gravity. Basically just the overall physics of pole dance...
Analyzed from the dancer's point of view, there arises fictitious centrifugal forces which point horizontally outwards. This force means that the dancer will not hang vertically down, but make some angle with respect to the pole. You just add the centrifugal force to the gravitational force, and you will find that the faster you spin, the more horizontal you get. This is the same principle behind tether balls.
Matterwave thanks for your reply could you give me some more info
But the downwards component is still the same. So that alone doesn't "make it easier to stay high on the pole and spin for longer". You have to consider the friction at the pole.
http://www.bing.com/videos/search?q...3A60530ACE6D769573FE&view=detail&FORM=VIRE1#a
After watching several of the talented ladies ( All I saw was ladies, no males, doing what should be an Olympic Sport, as it looks to be that someone has to be quite athletic and artistic to appear to make it look easy ), I conclude that there is more to the technique than just a simple answer. Some of the individuals do not slide down the pole when spinning, and not at all that rapidly. Except for the fireman move, and a few other moves, some could hang on the pole with it tucked under there knee joint and spin at one horizontal location. Perhaps a professional pole dancer can provide an answer to their secret.
While increasing the friction involves increasing the horizontal contact forces, it doesn't always involve spinning.
Not a pole dancer but I have done some pole shopping with my wife.
Some, but not all, dance poles are supported by bearings at the top and bottom so that the pole can spin. Friction between the dancer and the pole can be completely static while she is spinning.
Static friction is greatest so having a free rotating pole must help.
When spinning, there is a centripetal force involved and that will increase the friction force (normal force would be proportional to the square of the angular velocity) and reduce the grip needed. For a high enough rotation speed, it would not be necessary to grip at all.
Where does one go "pole shopping", I wonder. (Except in Krakow, perhaps)
So from a pole dancer point of view there are a few things to keep in mind. First of all there are poles that are static and there are poles that spin. Both give completely different effects while dancing on them (that's why competitions often offer two poles on stage, one being static, the other being spinning)
Static poles give you les friction when you're spinning, so it takes more muscles to stay up/make more spins while spinning. It however gives you way more balance, because when you go upside down for instance you only have to focus on gravity and not on keeping the pole steady making it the better option for 'harder' moves or to practice new moves. The spinning poles provide you with heaps of friction when you're spinning, because the pole is spinning and you yourself are static onto the pole.
The centrifugal force makes the pole accelerate when you are closer to the pole and slow down when you for instance extend a leg or arm.
Other 'funny' forces:
When you stand up straight in the pole (so pole alongside your whole legs) it is harder to grip and stick than when you stand the same way upside down, because of the gravity pulling on the fatty bit of your thighs and that way giving you more surface to stick.
Hope this helps;)
Your physics explanation for this is incorrect. You spin faster when you are closer to the pole due to conservation of angular momentum, not due to the "centrifugal force", which is a fictitious force.
This is also an old thread from 2014.
Zz.
That's alright.
As one the original 2014 contributors to this thread, I'm still interested in new insights on the topic. Poll dancing never gets old :-)
And while Zapper is right about the terminology, I was able to understand what you meant, and I appreciate the new perspective / info on the topic.
1. How does momentum play a role in pole dancing?
Momentum is the product of an object's mass and velocity. In pole dancing, momentum is utilized by the dancer to execute various moves and tricks. For example, when a dancer spins around the pole, they generate momentum by pushing off of the ground and using their body weight to increase their speed. This momentum allows them to execute more complex moves and maintain their balance.
2. What is the role of gravity in pole dancing?
Gravity is a force that pulls objects towards the center of the Earth. In pole dancing, gravity plays a crucial role in maintaining balance and stability. The dancer must constantly adjust their body position and use their muscles to counteract the force of gravity and stay on the pole. Additionally, gravity also helps the dancer create momentum by pulling them towards the ground during spins and flips.
3. How does understanding physics benefit pole dancers?
Understanding physics, specifically concepts like momentum and gravity, can greatly benefit pole dancers. It allows them to have a better understanding of the forces at play and how to use them to their advantage. This knowledge can also help prevent injuries by teaching dancers how to distribute their weight and maintain proper form while performing various moves.
4. Is pole dancing a physically demanding activity?
Yes, pole dancing requires a high level of physical strength, flexibility, and endurance. It combines elements of dance, gymnastics, and acrobatics, making it a full-body workout. Dancers must have strong core, arm, and leg muscles to execute moves and maintain balance on the pole. Regular training and conditioning are necessary to become a proficient pole dancer.
5. Can anyone learn pole dancing, regardless of their body type?
Yes, anyone can learn pole dancing, regardless of their body type. While having a certain level of strength and flexibility can make it easier, pole dancing is a highly adaptable activity that can be modified to suit different body types and abilities. With proper training and practice, individuals of all body types can excel in pole dancing and reap its many physical and mental benefits.
  • Other Physics Topics
  • Electromagnetism
  • Classical Physics
