MHB No Integer x for Which $P(x)=14$ Given Four Integer Values of $P(x)=7$
  • Thread starter Thread starter kaliprasad
    Integer
A polynomial P(x) with integer coefficients that equals 7 at four distinct integer values implies that the polynomial can be expressed as P(x) - 7 = (x-a)(x-b)(x-c)(x-d) for integers a, b, c, and d. This means P(x) - 7 has at least four roots, indicating that it can be factored accordingly. If we assume there exists an integer x such that P(x) = 14, then P(x) - 14 = 0 would have to have a root, leading to a contradiction since P(x) - 7 = 0 has already accounted for all roots. Therefore, it is impossible for P(x) to equal 14 for any integer x. The conclusion is that no integer x exists for which P(x) = 14.
kaliprasad
MHB
Show that if a polinomial $P(x)$ with integer coefficients takes the value 7 for four different integer values of x then there is no integer x for which $P(x) = 14$
Mathematics news on Phys.org
let $P(x)=Q(x)(x-a)(x-b)(x-c)(x-d)+7$
that is $P(a)=P(b)=P(c)=P(d)=7$
where $a,b,c,d$ are four different integer values
and $P(x),Q(x) $ with integer coefficients
if e is another integer value and $P(e)=14$ then we have
$P(e)-7=7=Q(e)(e-a)(e-b)(e-c)(e-d)----(1)$
where $Q(e),(e-a),(e-b),(e-c),(e-d)\in Z$
this is impossible for 7 is a prime ,and the proof is done
(1) can be true if $Q(e)\in Q$
P(x) -7 is zero at 4 different values say a,b,c,d
hence
$P(x)-7 = Q(x)(x-a)(x-b)(x-c)(x-d)$
or
$P(x)= Q(x)(x-a)(x-b)(x-c)(x-d)+7 $
Let
$P(t) = 14 = Q(t)(t-a)(t-b)(t-c)(t-d)+7 $
hence $Q(t)(t-a)(t-b)(t-c)(t-d)= 7 $
so 7 must have 5 factors out which 4 are different. but 7 cannot have 2 different factors (7 * -1 * -1 ) or (7 * 1) so above relation cannot be true so there is no solution
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
