Calculating Minimum Energy of Photons in Ionization and Relativistic Corrections
In summary, according to the information given, the emitted photons have a minimum energy of 377.9153 eV.
BRN
108
Hi at all! I need one more help from you.
1. Homework Statement
123.4 eV photons ionize further a rarefied gas of ##B^{2+}## ions. A small fraction of electrons emitted in this process is immediately captured by ##B^{3+}## ion, going to occupy the states 2p, 3p, and 3d. Calculate the minimum energy of the photons emitted in the process of capturing, in the not relativistic approximation. How does the result taking into account the relativistic corrections order α2? Do you remember the relativistic correction (multiplicative) to the eigenenergy of motion in the Coulomb potential: ##[1+\frac{(Z\alpha)^2}{n}(\frac{1}{j+1/2}-\frac{3}{4n})]##.
I admit that I have no idea on how to solve this exercise. The minimum energy of emitted photons is
##E=h\nu=h\frac{c}{\lambda}##
How can I know the wavelength knowing the states that are occupied?
Or maybe I have to totally change approach with this exercise ...
Think about the process: an electron is being captured by an ion. What is the smallest change in energy possible of the electron + ion system?
But the states 2p 3p 3d give me useful information?
What do you think? Does this knowledge change the answer, in other words, if the final state could be 4d, would that change the minimum energy of the emitted photon?
Again, think about the process and teh change in energy of the system. If a photon is emitted, its energy must come from the ion + electron system.
After capture process, I have this configuration: 1s2 2p 3p 3d
Then, the system energy is:
##E_{tot}=-\frac{\mu}{m_e}\frac{E_{Ha}}{2}(\frac{Z^2}{1^2}+\frac{Z^2}{2^2}+\frac{Z^2}{3^2})##
with:
##E_{Ha}=\frac{m_e e^4}{\hbar^2}## Hartree energy;
##\mu##= reduced mass.
Is correct?
Don't kill me please!
BRN said:
Is correct?
No.
Too late. You already sold us your soul when you registered at PF. Didn't you read the rules? :devil:
Seriously, I think you need to consider that only one electron is captured by a given atom. Also, you need only to consider the difference in energy for the before and after situation.
Sorry for delay,
If I consider one electron, I have:
before 1s2 2s2 2p
##E_{tot}=-\frac{\mu}{m_e}\frac{E_{Ha}}{2}(\frac{Z^2}{1^2}+\frac{Z^2}{2^2})=-425.1547 [eV]##
after 1s2 3d
##E_{tot}=-\frac{\mu}{m_e}\frac{E_{Ha}}{2}(\frac{Z^2}{1^2}+\frac{Z^2}{3^2})=-377.9153 [eV]##
with:
##M=A*1.6605*10^{-27}[kg]=1.7933*10^{-26}[kg] \Rightarrow \mu=\frac{Mm_e}{M+m_e}=9.1088*10^{-31}[kg]##
then:
##\Delta E= 47.23 [eV]##
but solutions are: 14.5545 eV; with relativistic corrections: 14.5400 eV
Consider a single electron going from ionized to captured by the atom.
There is something that is not clear...
But, how I conseder Z?
Before ##B^{2+}=1s^22s \rightarrow Z=2##
After ##B^{3+}=1s^2 2p## or ##1s^2 3p## or ##1s^2 3d \rightarrow Z=3##
No one else can help me?
1. What is a photon's energy?
A photon's energy is the amount of energy carried by an individual photon, which is a fundamental particle of light and other forms of electromagnetic radiation.
2. How is a photon's energy related to its wavelength?
The energy of a photon is directly proportional to its frequency, and inversely proportional to its wavelength. This relationship is described by the equation E = hf, where E is energy, h is Planck's constant, and f is frequency.
3. Can a photon's energy be measured?
Yes, a photon's energy can be measured using various techniques such as spectroscopy, which involves analyzing the spectrum of light emitted or absorbed by a substance.
4. How does the energy of a photon affect its behavior?
The energy of a photon determines its behavior and properties, such as its color, intensity, and ability to interact with matter. Higher energy photons have shorter wavelengths and can penetrate deeper into matter, while lower energy photons have longer wavelengths and are more easily absorbed or scattered.
5. Can a photon's energy be changed?
Yes, a photon's energy can be changed through interactions with matter, such as absorption, emission, or scattering. These processes can alter the frequency and wavelength of a photon, thereby changing its energy.
