Population modelling
"The very simple population model for a resource limited population with constant immigration, and no breeding, M'(t) = M(S-M) + I attempts to describe the growth of corals on a reef. Function M(t) represents the biomass of corals."
a - Explain which term gives the immigration of juveniles onto the reef.
b - Describe the presumptions being made about the growth rate of corals at their different ages and sizes.
c - Determine if the biomass of corals tends to a limiting amount as [tex]t \rightarrow \infty[/tex] .
d - Suppose a coral reef has completely died, due to excessive cyanide fishing. Find and describe what this model suggests will be the pattern of its recovery.
a - Is the immigration denoted as "I", because as immigration is constant, the I has 'constant effects' on the equation?
b - Is it correct to presume that the growth rate of the corals are constant, irregardless of their age and size?
c - I can see that its a first order non linear differential equation. But where do I go with this?
d - a regrowth rate represented by a logarithmic function?
The total marks for the 4 questions is 5 marks - if that helps
Thanks to all help received :)
Answers and Replies
HallsofIvy
41,833
964
Yes, I is the only thing that does not depend upon the current mass- it "comes from the outside".
Yes.
If there is a "limiting population", the rate of change as M nears it must decrease to 0. Is there a value of M such that dM/dt= 0 (so that M is constant)? Set M(S-M) + I = 0 and solve for M.
In other words, solve the problem M'= M(S-M)+ I, M(0)= 0, a separable differential equation. No, M is not logarithmic.
So what I've done is, I've found the value of M using the quadratic formula, this is in terms of S. Is this all I have to do? It feels inadequate...not that i'm undermining your way of thinking... I probably stopped short...
so if i directly integrate M'= -M^2 + SM + I, which will presumably give the function for M, which is: [tex]M = \frac{-M^3 }{3} + \frac{SM^2}{2} + IM + C = 0 [/tex] >>> is this what you're talking about? if so, I then substitute M=0? I'm getting lost...
Thank you for your help HallsofIvy :) Much appreciated :)
Related Threads on Population modelling
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
