Positive/negative electron transfer?
Positive and negative objects can charge by conduction if they are conductors. To charge a conductor negatively, bring a positively charged object near it, ground the conductor, and then remove both the ground connection and the charged object. A similar process can be used to charge the conductor positively. To return the conductor to a neutral state, it must be grounded again. This discussion highlights the principles of static electricity and charge transfer.
Cheesycheese213
Can a positively charged and negatively charged object charge by conducting? If so, is it possible to make a neutral charge again?
Yes and yes but the objects must be conductors.
Likes Cheesycheese213
This appears to be a straight forward static electricity case.
Hold a positively-charged object near the isolated conductor. Ground the conductor. Remove the connection to ground, and THEN remove the positively-charged object. Now the conductor is negatively charged.
Similarly procedure to charge the conductor positively.
To make the conductor neutral again, ground it.
Zz.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
