B Possible to see the moons of Jupiter/Saturn with decent set of binoculars?
  • B
  • Thread starter Thread starter Alltimegreat1
    Moons Set
Jupiter's larger moons are easily visible with decent binoculars, such as 7x35 or 8x40, allowing observers to track their movement over nights. Saturn's moons, particularly Titan, may be visible with high-quality binoculars, but spotting them is more challenging due to the planet's distance. A steady view is crucial for observing these celestial bodies, and using a tripod can significantly enhance the experience. While Mars' moons are too small to be seen with binoculars, other bright deep-sky objects can be explored effectively with modest binoculars. Overall, binoculars provide an accessible way to enjoy and explore the night sky, especially for beginners.
Alltimegreat1
Assuming clear night skies
Astronomy news on Phys.org
I'm pretty sure you could see the bigger moons of Jupiter, after all Galileo managed to see them with a primitive telescope which was probably less powerful than modern binoculars.
Saturn, hmm, I guess you might be able to see the biggest moons with top of the range binoculars, not sure.
I've seen them all with binoculars. Jupiter's 4 moons aren't only visible, but fairly obvious. Titan, you'll have to search for, but it's possible to see it.
Assuming good binoculars ;)
You can definitely see Jupiter's moons with a modest pair of binoculars (7X35). However, what you see is a BRIGHT star with 2-4 tiny low magnitude stars aligned with the Bright star (Jupiter). If you watch this from night to night, you will see the tiny moons move into different positions (orbit Jupiter). Galileo recognized this after several days (or weeks) of viewing as this was a revolutionary discovery.
Saturn is 2X further away and you MIGHT possibly see one moon. The rings themselves may even appear as two separate points of light, but that depends upon their orientation to us ie edge on, you will see nothing, even with a big telescope.
They key to seeing these objects with binoculars is holding the binoculars steady. A decent pair of binoculars has more than enough optical power to see Jupiter's moons, but it is hard to see them well if the image is dancing around because you can't hold them steady. A tripod mount for the binoculars helps a great deal.
What about looking at Mars' moons with binoculars?
No, you will not see anything. Even a moderate sized telescope will not resolve either of Mars's moons. They are small.
Likes russ_watters
Not a chance, those things are tiny.
I think the only celestial objects that look like anything through binoculars would be: Mercury, Venus, The Moon, Mars, Jupiter w/ 4 moons, Saturn w/ Titan, and maybe the Andromeda Galaxy and Orion Nebula.
Likes davenn
and a host of other bright deep space objects
many open cluster, a good number of the brighter globular clusters, many nebulae other than the Orion Nebula
M8 = Lagoon Nebula, M20 = Trifid Nebula, M13 globular cluster, Omega Centauri globular cluster = brightest in the sky
( also naked eye visible), just to name a few
Andromeda galaxy is naked eye visible from a dark site, and much better in bino's
a reasonable pair of bino's ... 7 x 35, 7x50 ( my choice) will give you years of fun exploring the night sky
Dave
The ones I have are 8x40 (Olympus). I tried this evening but it was too wobbly. I need a tripod. Are 8x40 binoculars powerful enough to spot some Jupiter moons?
They should be OK ( I personally, not that I can remember, have used a pair of 8x40) ... pure handheld, yes, difficult
lean them up against something ... eg. a fence, a power pole, the corner of the house
Dave
Almost any binoculars will be able to spot Jupiter's moons. They are nearly naked eye visible.
Thanks for all the very helpful responses. Just one more question. How do I know which moon is which? Is there a website that shows their current positions around Jupiter? Also, I assume not all 4 moons are always visible as some may be on the back side of Jupiter and blocked from view. Last night I could only see 1 to the right of Jupiter. I'll try to stabilize the binoculars tonight.
Just a note: Magnification is only important in the sense that you need enough to separate the moons from Jupiter itself. Past that, magnification is of little use and just makes it harder to steady the view in the binoculars. If you buy another pair, don't go for the highest magnification. Keep it modest. For binoculars, 8x40 means that they have 8x magnification and a 40 mm aperture. I don't personally use binoculars, but I think that once you get to 10x your binoculars become essentially impossible to use without a mount or a stand since the field of view bounces around so much in your hands.
See this article for more info: http://www.skyandtelescope.com/astronomy-equipment/binoculars-for-astronomy/
I use a pair of 15 x70 Skymaster binoculars by Celestron in an almost dark sky area. I can usually see 2 moons of Jupiter and about 15 galaxies. I really enjoy using these binoculars over my telescope because I can do so much more in 20-30 minutes.
Likes Drakkith
My wife & I were driving west on US70 near the state line of Colorado / Kansas. We stopped for a rest and it was an incredibly dark sky. With our binoculars we could see several moons around Jupiter. The moons were tiny dots around Jupiter.
With a large (>10") telescope and a dark, clear night, you will be able to see many of Saturn's moons, including Titan, Enceladus, Dione, Tethys, and Hyperion. When I was an undergraduate at Valdosta State, one of my seminar assignments was to estimate the density of Saturn by watching the moons go around, measuring their distances from Saturn's center, as well as the radius of Saturn, in angular units with a filar micrometer.
From Kepler's third law as Newton wrote it:
P² = 4π²a³/(GM)
And from the formula for the average density of a spherical mass:
ρ = 3M/(4πR³)
You can get:
ρ = 3π(a/R)³/(P²G)
Notice that the mass of Saturn, M, cancels out. (Approximately, that is. We neglected the mass of the satellite when finding its orbital period.) Also, notice that the units cancel out on the distances. All you need are the ratios, corrected for the tilt of the ring plane and for the azimuth of the satellite with respect to Saturn within that plane.
But yes, you can see Saturn's moons too, with a good amateur telescope.
New to this site, good to still I can post to a six year old thread. Late September I heard that due to Saturn's close distance currently it was possible to see its moons with binoculars. On Oct 2 I got out my 10x50 pair and sure enough, I could see two bright points of light to the left of Saturn, quite a thrill. I wondered which moons they were but didn't think to look it up, which I since have learned I could have easily done. In the last few nights, having apparently clear viewing conditions, I've tried again, but no moons. I don't know if that's because of increasing distance, or current position of moons, or what.
Likes vanhees71 and Drakkith
Saturn only has one moon visible with binoculars; Titan. The other object would have been a star. It's hard to tell the difference.
It's possible the second time that Titan was in front of Saturn, behind or so far away you didn't realize what it was.
What day/time was the second viewing? We can tell you exactly where it was.
It is barely possible that one can see Ganymede and maybe even Callisto with the naked eye. Arago (yes, that Arago) was interested in this and build a special "1x" telescope to test this.
The problem is not that the moons are dim - they are actually about as bright as Uranus - it's that they are close to something bright, Jupiter. I am thinking an overhead phone line might be used to occult Jupiter and see the outermost Gallilean moons.
Usually the argument for telescopes is that magnification is unimportant and light gathering ability is vital. This is somewhat of an exception, because what you want is to increase the apparent separation between the bright planet and dimmer moons.
Likes russ_watters, phyzguy, Ibix and 1 other person
