Possibly incredibly stupid question about gravity in an aeroplane
  • Thread starter Thread starter jessb
    Gravity Stupid
When flying in an airplane, a person's weight does not change significantly due to the distance from the Earth's center, as gravity diminishes very slightly with altitude. However, the apparent weight may vary due to changes in normal force during flight maneuvers. The difference in gravitational pull at cruising altitudes is about 0.4%, which can be measurable with sensitive scales. For example, a 150 lb person would weigh approximately 0.1 lb less at altitude compared to sea level. Thus, while weight remains largely unchanged, slight variations can be detected under specific conditions.
jessb
I just want to make absolutely sure, but does anyone know if you actually do weigh less in a plane, and if you do, is it measurable?
Obviously a flying aeroplane, and not one on the ground ;)
Thanks! Jess
Thanks! Jess
You already weigh less when you are high up in the mountains. That's why places such as Denver, CO, and other cities up in the mountains have "thinner air".
Since an airplane travels higher than even these mountains, you can draw your own conclusion from there.
Zz.
except maybe on take off and in curves
Your weight would still not change. Weight is a function of distance only, nothing else. Your apparent weight may change, i.e. the magnitude of the normal force from your seat.
Zz.
I guessed as much... but is it measurable? o:) (on regular scales like you would have in your bathroom)
it seems to me, it would be when (a moment in time) and where (an exact location/circumstance in that moment of time) when you would weigh yourself (weigh less)---wouldn't you weigh less on the moon?
I think what he was saying was that the pull of the Earth on your body would still be the same in the plane if it was doing a parabolic flight and you appeared weightless, or if it was a regular flight and you didn't, so long as you were at the same distance from earth?
Zz.
You weight less as you climb. But this is not the reason why the atmospheric pressure diminishes with height.
Atmospheric depends on the weight of the air column from de place you are until free space.
Although gravity diminishes with height, it does so far much slowly than atmospheric pressure.
As an example, in the summit of the Everest, gravity is only 0.25% lower than at sea level, but atmospheric pressure is just 35% of sea level pressure.
Earth radius = 6400 Km (approx).
Typical cruise height of civil aircraft = 35,000 ft = 11 Km.
Change in gravitational attraction (a.k.a. weight) = (6400/6411)^2 = 0.996
A 0.4% change isn't hard to detect.
It might, depending on how good your bathroom scale is (mine reads up to 1 decimal place).
The approximate difference in g between Denver, CO and sea level is about 0.06%. So for a 150 lb person, the change is weight between the two is about 0.1 lb. So yes, you can detect this with a bathroom scale.
Zz.
OK--if that's what your specific circumstance was in your original question
Zz.
Thanks! That's really helpful :D
Jess
You would indeed weight less on the moon, but how many aeroplanes fly on the moon...
well since there's no aer on the moon---not many I would guess---
just nailing down the specific circumstance.
If I'm not mistaken though, if you had the scale on the plane with you, and weighed yourself---I believe you'd weigh the same as if you weren't on the plane (on earth) and weighing yourself--I think it would depend on what type of scale you were using too.
