Potentetiometer - position of slider
  • Thread starter Thread starter damon669
    Position Slider
The discussion revolves around a homework problem involving a potentiometer and the determination of the slider's position when a specific voltage is measured across a load resistor. Participants explore the application of voltage division and equivalent resistance in the context of circuit analysis.
  • Homework-related
  • One participant presents a circuit diagram and attempts to calculate the current through the potentiometer and load resistor.
  • Another participant suggests using a voltage divider approach and defines variables for the resistances and voltages involved.
  • There is a discussion about the graphical representation of the circuit and the configuration of resistors.
  • Participants debate the correct application of formulas and the conditions under which they can be used, with some expressing confusion about the derivation of certain equations.
  • A later reply introduces the concept of the position of the slider as a variable affecting the equivalent resistance and current calculations.
  • One participant proposes a quadratic equation to solve for the position of the slider, while another confirms its necessity.
  • Finally, a participant presents a detailed calculation leading to a proposed solution for the slider's position, which is met with general approval from others.
While some participants agree on the approach to solving the problem, there are disagreements regarding the application of certain formulas and the interpretation of the circuit configuration. The discussion includes multiple competing views on how to correctly analyze the circuit.
Participants express uncertainty about the derivation of formulas and the assumptions behind their use. The discussion reflects a reliance on specific circuit configurations and the implications of the slider's position on the overall resistance and voltage measurements.
damon669
https://www.physicsforums.com/attachment.php?attachmentid=60570&stc=1&d=1375128608
Thew circuit shows a 10KΩ potentiometer with a 5KΩ load. determine the position of the slider on the 'pot' when tthe voltage across points 'XX' is 3V
Vi=IR
I=V/R = 12/10x10^3 = 0.0012A = 1.2mA
Vo=IR
I=Vo/Io = 3/5x10^3 = 0.0006A = 0.6mA
Vi/Ri+Ro = 9/10x10^3 + 5x10^3 = 0.6mA
VD Across Ri =Vi =RiVi/Ri+Ro = RiVi/R
Let x = fraction of distance from ground to wiper.
Call the potentiometer resistance (10K) = R1 and the external resistor (5K) = R2.
Call 9V = Vi and wiper voltage = Vo = 3V.
Then redraw your circuit so that Vo/Vi consists of a voltage divider between two equivalent resistors.
What is the equivalent resistor going from Vi to Vo?
What is the equivalent resistor going from Vo to ground?
Solve for x.
That is right.
I would align the two resistors to be in the same column, but that is just a graphical thing and does not influence the electric properties.
so now to answer the question
I need to find the new parallel resistance which is (R_1 R_2)/(R_1+R_2 )
=33x10^3 ohms
Then I think I have to put 3 V in the equation?
The parallel resistance should depend on the position of the slider, and don't forget the third resistor in your analysis.
What do you mean with "put 3 V in the equation"? Just do it.
=33x10^3 ohms
Your diagram is correct. But the parallel resistance is obviously a function of p.
yes, put 3V at the output and solve the whole thing for p.
I think somebody needs to get the glove puppets out :)
Vl=RoVi/R1+R2
3=Ro•9/(10•10^3)+(5•10^3)
= 5k ohms
I don't understand where that formula comes from. And where did you define all those parameters?
Vl = 3 volts across the load
Ro = what I'm trying to find
Vi = voltage on the circuit
R1 = 10k ohms
R2 = 5k ohms
That formula came from my notes
voltage division.
is it correct then?
R1 = 10k ohms
There is no 10kOhm-resistor in your network.
It should come together with a circuit where you can apply it. You cannot just use a formula for some circuit here.
10k ohm is the max position of the slider @ 9V
Sure, but 10kOhm is not a single resistor in your network.
The maximal position of your slider is not the solution to this problem.
If the slider was at 5k ohm would that not give 3 volts across the load?
It would, but I think it is an accident that the formula gives the right result.
Try to do the same calculation for 0V, 9V and 4V, and see what you get (and show what you plugged in where please). Are the results reasonable?
Can this be done without using a Quadratic equation?
No, but it's a piece of cake - especially if you use Wolfram Alpha! :smile:
so you DO have to use a Quadratic to solve then
Yes.
OK this is what i got then
Let p represent the position of the ‘pot’ slider where 0≤p≤1 (i.e. the proportion of the ‘pot’ resistance that is in parallel with the load resistor). For p=0 the slider is at the bottom (minimum resistance) and for p=1 the slider is at the top (maximum resistance). The equivalent circuit is shown below.
The parallel resistance R_P is given by
R_P=(10p×5)/(10p+5) kΩ
=50p/(10p+5) kΩ
=10p/(2p+1) kΩ
and the current I is given by
I=9/〖10(1-p)+R〗_P
=9/(10(1-p)+R_P ) mA
The voltage V_L across R_P is
V_L=I×R_P
=(9R_P)/(10(1-p)+R_P )
=(9×10p)/(10(1-p)(2p+1)+10p)
Now V_L=3 so
3=(9×10p)/(10(1-p)(2p+1)+10p)
3=9p/((1-p)(2p+1)+p)
(1-p)(2p+1)+p=3p
2p+1-2p^2-p+p=3p
0=2p^2+p-1
Therefore,
p=(-1±√(1-2(2)(-1) ))/(2×2)
=(-1±√9)/4
=(-1±3)/4
Since 0≤p≤1 then p=0.5. Thus the slider is at the midpoint position of the ‘pot’.
Check: R_P=2.5 kΩ which is in series with a resistance of 5 kΩ so the voltage V_L across the load is
V_L=(9×2.5)/(2.5+5)
=3 V
Looking good. I didn't check all your math but you have the right approach & the answer is of course correct also.
  • · Replies 50 ·
9K
  • · Replies 34 ·
15K
10K
