Potential Barrier (quantum mechanics)
8 replies · 4K views
roam
I need help with part (iii) and (ii) of the follwoing problem:
http://img228.imageshack.us/img228/516/79620850.jpg
From my notes transmission coefficient for E<U is:
[tex]T(E)= \left[ 1+\frac{1}{4} \left( \frac{U^2}{E(U-E)} \right) sinh^2 (\alpha L) \right]^{-1}[/tex]
And for E>U it is:
[tex]T(E)= \left[ 1+\frac{1}{4} \left( \frac{U^2}{E(E-U)} \right) sin^2 (k' L) \right]^{-1}[/tex]
Where [tex]k'=\frac{\sqrt{2m(E-U)}}{\hbar}[/tex] and [tex]\alpha =\frac{\sqrt{2m(U-E)}}{\hbar}[/tex].
So for part (ii). I used the first equation and got a value of 4.59x10-4. This doesn't seem like a correct number for the number of neutrons. So do I have to multiply this with the total number of neutrons? :confused:
For (iii) I am confused and I don't know which equation to use. We know the equation when E<U and when E>U, but what exactly is the equation for when E=U?
I don't quite understand the hint, does this mean we need the following equation:
[tex]T(E)= \left[ 1+\frac{1}{4} \left( \frac{U^2}{E(U-E)} \right) \alpha^2 L^2 \right]^{-1}[/tex]
Is that right?
And for E>U it is:
What does T(E) represent? If you understand that, it should be clear how to proceed.
Is that right?
Yes. Substitute in for ##\alpha## now.
Thank you for your reply. I believe T(E) represents the probability of the particles being transmitted relative to the total incident particles. So isn't it correct then to multiply it by the total number of particles to see how many are transmitted?
In that case I will have (106)x(4.59x10-4)=459
But doesn't ##\alpha## equal to 0 when U=E?
##\alpha = \frac{\sqrt{2(1.675\times 10^{-27})(4MeV-4MeV)}}{1.054 \times 10^{-34}} = 0##
This will make the whole T(E) expression equal to 1, so that means that all the particles get transmitted? Is that right or did I make a mistake?
roam said:
Thank you for your reply. I believe T(E) represents the probability of the particles being transmitted relative to the total incident particles. So is isn't it correct then to multiply it by the total number of particles to see how many are transmitted?
Exactly, T(E) is the fraction that gets transmitted.
This will make the whole expression equal to 1, so that means that all the particles get transmitted? Is that right or did I make a mistake?
No, remember the expression for T(E) is valid for E<U, so U-E isn't 0. Do the substitution and simplify, and then take the limit as E approaches U.
Thanks, so I guess it is correct to multiply T(E) by the total number of particles.
I see. So here is what I did:
##\lim_{E \to U} \left( 1+ \frac{1}{4}\frac{U^2}{E(U-E)} . \frac{2m(U-E)}{\hbar^2} L^2 \right)^{-1}##
##\lim_{E \to U} \left( 1+ \frac{mU^2}{2 \hbar E} L^2 \right)^{-1}##
And since for small x we have (1+x)-1=1-x,
##\lim_{E \to U} \left( 1- \frac{mU^2}{2 \hbar E} L^2 \right)^{-1} = \frac{mU^2}{2 \hbar U} L^2##
Is this correct now?
No, you made algebra mistakes, and you shouldn't approximate using a series.
Oops that was a typo, here is what I've got
[tex]\lim_{E \to U} \left( 1+ \frac{mU^2}{2 \hbar^2 E} L^2 \right)^{-1}[/tex]
I have substituted the limits first and it is possible to take the inverse later:
##T(x)=\left( 1+ \frac{mU}{2 \hbar^2} L^2 \right)^{-1}##
Is that fine now?
