Potential energy of a system of conductors
The discussion focuses on the potential energy of a system of conductors as described by Jackson's formula, which involves coefficients of capacitance (C_ii) and induction (C_ij). The derivation for a parallel plate capacitor leads to a familiar result, but questions arise regarding the meaning of the coefficient C_22, particularly in relation to the geometry of the plates. It is clarified that C_22 represents the capacitance between the two plates when one is set to a reference potential, typically zero. The conversation also explores the implications of adding a third conductor, questioning how the coefficients would represent capacitance and inductance in such a system. Understanding these coefficients is essential for further analysis of multi-conductor systems.
univox360
According to Jackson the potential energy of a system of conductors is
W=\frac{1}{2}\sum_{i=1}^n\sum_{j=1}^n C_{ij} V_{i}V_{j}
He calls the coefficients C_{ii} coefficients of capacitance and C_{ij} coefficients of induction.
I want to derive from this formula the well known result for a parallel plate capacitor, top plate of potential V1 and bottom plate of potential V2.
Certainly,
W=\frac{1}{2}(C_{11} V_{1}V_{1}+C_{12} V_{1}V_{2}+C_{21} V_{2}V_{1}+C_{22} V_{2}V_{2})
And if we make the substitution
V_{2}=V_{1}+\Delta V_{12}
And then set V1 to zero,
W=\frac{1}{2}C_{22} (\Delta V_{12})^2
Which is the familiar result. However, my question has to do with what C22 actually is. Since I am only familiar with capacitance of a system the term C22 doesn't make sense since the indices only involve the top plate, unless it is some sort of self capacitance. But that doesn't make sense either since we know that the energy between the plates is dependent upon the plate-plate geometry.
I need to solve this problem with more conductors but without a sense of what the coefficients actually are I cannot continue.
Capacitance is always defined w.r.t. a potential difference as follows -
If we charge a conductor to a value Q, what would be its potential V w.r.t. a reference potential (in effect a potential difference)? Capacitance is then given by C = Q/V.
Now, The formula in jackson assumes an arbitrary reference potential w.r.t. which all the potentials V_i are calculated. What is meant by C_{ii} then is the capacitance b/w the conductor i and the reference conductor which is at a potential zero.
In the formula you derived you set the reference potential to be V_1=0 In effect C_{22} defines the capacitance b/w 1 and 2. You could alternatively have set V_2=0, then C_{11} would define the capacitance b/w 1 and 2.
Usually the reference potential is set to be 0 at infinity. One could then measure the capacitance of a single conductor, e.g. sphere, or spherical shell, etc.
That seems reasonable.
What if we had a system of three conductors?
If I were to set, say conductor one to potential zero, would the coefficient C22 still correspond to the capacitance between conductor two and the conductor held at zero?
Also, what would the term C23 correspond to? Is that the inductance of conductors two and three with respect to the conductor held at zero?
Thanks!
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
