Potential Energy -- What are the different ways it can be stored?
Potential energy can be stored in various forms, including gravitational, electrostatic, and elastic potential energy. It is defined as the work needed to move a mass from one position to another within a force field. Examples include mass at height, tense springs, and nuclear energy, which involves the conversion of mass into energy. The discussion emphasizes the importance of understanding potential energy at a fundamental level, noting that it can also be viewed as a mathematical construct. Overall, potential energy encompasses a wide range of physical phenomena and is crucial in both classical and quantum physics contexts.
neomahakala108
Potential energy is energy contained in certain system, for example in physical body mass in gravitational field of Earth.
Potential energy at initial position has value equal to work necessary to move mass from initial position to new position.
But also, i read that potential energy can also be stored in other ways.
It'd be nice if someone elaborated examples, especially interrested in Quantum Physics & Electronics examples.
Well, there's electrostatic potential energy, and elastic potential energy. You can assign a potential energy function to any conservative force field as far as I know.
Likes neomahakala108
Are you looking for a simple list? Why don't you start by listing what you can think of?
i know too little of physics & related english words to speak about this properly.
but i'll list examples:
- mass at height,
- tense spring (not sure if i translated this well),
- chemical energy (not sure if it's correct),
- solar energy (not sure if it's correct).
Solar energy isn't a good example. Solar energy comes from nuclear fusion reactions of hydrogen and heavier elements. But there are nuclear reactions happening outside the sun, also. So it is better to put nuclear energy in the list rather than solar energy. Any nuclear or chemical reaction that gives off energy converts a small amount of mass into energy, so you could consider all mass to be a form of potential energy, depending on context. Any mass at rest can in principle be completely converted to kinetic energy (including photons) by annihilating it with an equal supply of antimatter.
It might be useful to consider how potential energy is stored at a more fundamental level. Springs and other elastic objects store energy in the electric field, since it is the displacement of the chemical bonds which is responsible for the elasticity. Levitating a mass stores energy in the gravitational field. Nuclear fuel stores energy in the strong nuclear bonds.
I've given a very physical picture of potential energy, but you can also think of potential energy as a mathematical construct--a bookkeeping engine. I prefer to think of potential energy in terms of real measurable things.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
