Power and Energy - energy in a tidal power plant
A tidal power plant generates 10 MW of electricity over 12.5 hours, with water collected behind a 6m dam and passing through a turbine twice. The efficiency of the turbine is 85%, meaning the actual power used for calculations should be 8.5 MW. The gravitational energy produced is calculated using the formula E = P*t, resulting in 4.5 x 10^11 J, which must account for the energy being used twice as the tide comes in and goes out. The correct mass of water flowing through the turbine is derived from the gravitational energy equation, considering the average height of 3m for potential energy calculations. The discussion clarifies the importance of correctly applying the efficiency and the factor of two in energy calculations.
shaools
A tidal power plant generates 10 MW of electricity during a period of 12.5h. Assume that the water is collected behind a dam 6.0m high and is allowed to pass through a turbine twice to generate electricity, once as the tide comes in and once as the tide goes out. What mass of water flows through the turbine if the efficiency is 85%?
Given:
P=10MW= 10*10^6W
t=12.5h= 45 000s
h= 3m?
g= 9.8 N/kg
-the tide comes in twice, so I'll have to multiply the energy produced by two
-the efficiency is 85%, so power will have to be multiplied by 0.85
-the max height given is 6m, but there's an example problem in this textbook where the max height of the reservoir is 6m again, but they use an average height of 3m? I tried using both 6m and 3m.
Required:
mass of water
P=Eg/t
Eg=P*t
Eg=m*g*h
m=Eg/g*h
The problem seems simple enough but I can't seem to get the answer at the back of the book, which is 9.1*10^6 kg:
efficiency is 85%, so 85% of the power produced should be
P= 10*10^6W * 0.85
P= 8.5*10^6W
then, solve for the gravitational energy produced
Eg=P*t
Eg=8.5*10^6W * 45 000s
Eg=3.825*10^11J
the tide pass through the turbine twice, so
Eg=3.825*10^11J * 2
Eg=7.65*10^11J
plug this in into the equation for gravitational energy and solve for mass
m=Eg/g*h
m=7.65*10^11J/ (9.8N/kg*3m)
m=2.6*10^10kg
so, that didnt work... let's try with h=6m instead
m=Eg/g*h
m=7.65*10^11J/ (9.8N/kg*6m)
m=1.3*10^10kg
nope :/.
The first and most obvious problem that I see is your handling of the information given about the efficiency. 10 MW is the final power generated (the power that is usable electricity). What the question is saying is that the turbine WAS only 85% efficient in generating that 10 MW.
so then the answer i get for my gravitational energy should be divided by two, not multiplied right?
is there anything else wrong in the process?
Umm, no. That has nothing to do with anything. I'm saying that you're making use of the 85% wrong. Read what I said again.
10 MW is the output of the plant. You know this because it says that the plant produces 10 MW of electricity.
yes i understand now about the 85% now, thank you, but I am asking if there are any more errors.
you said "first and most obvious problem". if that's the first, what are the rest?
E=P*t
E=10*10^6W * 45 000s
E=4.5*10^11 J
so, the tide coming in twice doesn't have anything to do with anything, so ill leave out any dividing/multiplying by 2 that i thought i had to do. ill go straight to solving for mass.
m=Eg/g*h
m=4.5*10^11 J/ (9.8N/kg*3m)
m=1.5*10^10 kg
i really don't know what I am doing wrong :/.
No, I did not mean to imply that you had definitely made more errors than that. What I meant, when I said this, in fact, was that I had not looked more deeply into your solution for further problems and that this one was merely the first one that struck me.
No, I didn't mean to say that the tide going in and coming out twice was irrelevant to the problem. I just meant that it had nothing to do with what I was trying to say in my first post, which is what you seemed to be responding to.
Sorry for the confusion on both counts. I'll take a closer look at your work now.
shaools said:
E=P*t
E=4.5*10^11 J
For some reason, you are still not taking the efficiency into account properly. You went from doing it wrong to just ignoring it completely. Let me state this again. The 10 MW is the output of the power plant (in electrical energy). However, the plant is not 100% efficient, suggesting that the input to the plant was, in fact, greater than 10 MW, and that some of the water energy was lost due to the inefficiency of the plant. Now do you understand?
shaools said:
m=Eg/g*h
m=1.5*10^10 kg
What happened to the factor of two? If the water runs through the turbine twice, then that amount of gravitational potential energy is indeed being used twice. Also, isn't the height 6 m?
EDIT: Nevermind. 3.0 m is the height of the centre of mass of the fluid, which is how the gravitational potential energy is being measured. That's why 3.0 m is used. My bad.
OH okay.
thank you!
and sorry, thank you for your patience lol.
