Understanding the Power Map in Tensor Analysis: Bishop and Goldberg Page 6
  • Thread starter Thread starter pmb_phy
    Map Power
pmb_phy
I'm a bit confused as to how the text Tensor Analysis on Manifolds, by Bishop and Goldberg on page 6.
The authors define the term power set as follows
_________________________________________
If A is a set, we denote by PA the collection of all subsets of A, PA = {C| C is a subset of A}. PA is called the power set of A.
The authors define the term power map as follows
If f: A -> B, the we define the power map of f, f: PA -> PB by fC = {fc| fa is an element of C} for every C which is an element of PA}
What is confusing to me is that nowhere in the definition does the set B occur. What role does B have in the power map?
Thank you
Pete
I think your definition of the power set is a bit off here. Given a mapping f:A->B, where A and B are arbitrary sets, the power map is given by
f(C)={f(c): c is an element of C} for any subset C of A.
The sets A & B are just given sets. The power map is simply the concept that, if you are given a mapping from one set to another, A to B, then this mapping can be used to construct a mapping on the power set of A & B, i.e., one that sends each subset of A to some subset of B.
Thanks. But the set B does not appear in the definition of the power map, hence my question.
Pete
Well, it is there, even if it isn't specifically stated. For any subset C of A and any element c of C, f(c) will be an element of B (since f is a given function from A to B); and hence the image of the subset f(C) will be a subset of B. Hence, the power map is indeed a mapping from the power set of A to the power set of B.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
