How Does External Pressure Affect Internal Pressure Variation in a Sphere?
This discussion centers on the relationship between external and internal pressure variations in a sphere buried in an elastic medium. It establishes that if the medium is perfectly elastic and does not increase in pressure when the sphere expands, the internal pressure remains unchanged despite external pressure variations. The equation derived, P1 ΔV1 = ΔE = P2 ΔV2, illustrates the balance of pressures and volumes during displacement. The conversation emphasizes the importance of understanding the elasticity of the medium and the rigidity of the sphere's walls in determining pressure responses.
  • Understanding of basic fluid mechanics concepts
  • Familiarity with pressure-volume work equations
  • Knowledge of elastic materials and their properties
  • Basic principles of thermodynamics, particularly the Ideal Gas Law
  • Study the derivation of the equation P1 ΔV1 = ΔE = P2 ΔV2 in fluid mechanics
  • Learn about the properties of elastic media and their impact on pressure variations
  • Explore the Ideal Gas Law and its applications in pressure-volume relationships
  • Investigate piston-cylinder arrangements and their relevance to pressure work
Researchers, engineers, and students in the fields of fluid mechanics, material science, and thermodynamics who are interested in understanding pressure dynamics in elastic systems.
Jenq
TL;DR
pressure variations of a sphere subjected to different pressures
Hi
A sphere with radius r is buried in an elastic ideal medium at pressure P1.
Inside the sphere I use energy E to create a variation of pressure of dP.
What variation dPx I would measure if the sphere was buried in a medium at pressure P2 using the same energy E?
Is it possible to solve this problem?
Thank you
Jen
This "elastic medium". How does it respond to displacement? i.e. how does it respond when a spherical volume within begins to expand? How elastic is it?
For instance, is it a perfect fluid which responds by moving away with no increase in pressure at all?
How flexible are the walls of the sphere?
If perfectly rigid, how much would the internal pressure be affected by changes in the external pressure?
Yes, I am looking for a solution in the simplest conditions, e.g. perfect elastic medium that doesn't increase in pressure if the sphere expands.
I don't know the answer, for a perfectly rigid wall is it possible to find a relationship between the 2 pressures in steady conditions?
You asked for a result as a change in pressure in a medium that deflects with no change in pressure. That's an easy answer: Zero.
If you wanted to know about deflection instead, that's easy as well. ##\Delta E = P \Delta V##. Solve for delta V.
Edit: If you want to work on deriving that formula above, we can help with that. A good starting point would be a piston arrangement rather than an expanding sphere.
I believe that the original problem should have clarified that important detail.
Please, see:
https://en.m.wikipedia.org/wiki/Ideal_gas_law
A rigid wall or container would not allow any change in internal volume; therefore, if internal temperature does not change (because there is no thermal energy transfer through those walls), internal pressure must remain the same, no matter how much the medium pressure changes.
The opposite extreme would be walls that can be expanded much without offering much resistance or elastic force.
In that case, the internal pressure value would be very much close to the external one.
Think of a soap bubble, for example; its internal pressure must be equal to the atmospheric pressure surrounding it.
A rubber balloon would be an intermediate situation between those two extremes.
Ah sorry I misunderstood, I meant the pressure exerted by the external environment on the sphere does not change if the pressure / volume inside the sphere changes.
The equation is useful to me: so we can say that ## P_1 \Delta V_1 = \Delta E = P_2 \Delta V_2## where ##P_1## and ##P_2## are the external pressures, right? If so, yes I would like to read a reference on how to derive that equation.
Thanks
Please, see:
I see, then I think the case should fall into an intermediate situation. Otherwise in a pure elastic case the sphere should inflate till the internal pressure balances the external one ## \Delta P_x = \Delta P + P_2 - P_1 ## ?
Thank you for the useful link.
Instead of a sphere, assume that we have a cylinder under a pool of water. One end of the cylinder is closed. The other end is open to the water. There is a piston mounted in the cylinder. The piston is free to move within the cylinder. It makes a tight seal with the sides. Friction is negligible.
We remove the water behind the piston so that only vacuum remains. Obviously, the pool water is pushing on the piston. So we have to brace the piston, holding it stationary against the water pressure.
Now we use some energy, pushing the piston away from our brace on the vacuum side and out toward the open pool.
Let us call the pool pressure at the depth of the cylinder "P".
Let us say that the piston has cross-sectional area "A".
Let us say that we have used energy "E" to move the piston.
We ask: "much volume does the piston cover when we apply this energy E"?We can start with how much force there is on the piston. Force is equal to pressure times area.$$F=PA$$How much distance (##\Delta x##) has the piston covered? Work is equal to force times distance. So$$E=F\Delta x$$Solving for ##\Delta x## and substituting ##PA## for ##F##, we get:$$\Delta x = \frac{E}{PA}$$Multiply through by PA and we get:$$PA\Delta x = E$$How much volume (##\Delta V##) has the piston swept out? Well that is area times displacement -- ##A \Delta x##. So we get $$P \Delta V = E$$QED
  • · Replies 45 ·
