The discussion revolves around calculating the pressure drop across a thick orifice in a pipe system where the diameter changes from 1 inch to 0.5 inches and back to 1 inch. Participants explore the setup and solution for this problem, considering factors such as flow rate and the geometry of the orifice.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant seeks to understand how to calculate the pressure drop across the orifice, given a specific flow rate of water.
- Another participant suggests applying results from a previous discussion on pressure drop across a change in diameter, emphasizing the importance of dimensions in the calculations.
- Questions are raised about the required accuracy of the answer and the specific flow rate being used.
- A participant outlines their approach by dividing the problem into three regions and calculating a pressure drop of 0.088 psi across the orifice, questioning the correctness of their calculations and how to incorporate the length of the orifice.
- Further clarification is sought regarding the flow rate and the desire for accuracy in the solution.
- A reference to a textbook provides formulas for calculating pressure drop due to friction losses during sudden changes in cross-sectional area, introducing specific factors for contraction and expansion.
- Discussion includes considerations of flow development and pressure drop estimates for fully developed flow versus flow in the entrance region.
Participants express varying levels of understanding and approaches to the problem, with no consensus reached on the accuracy of calculations or the best method for solving the pressure drop across the orifice.
Participants mention the importance of flow rate and dimensions, as well as the need for clarity on assumptions regarding flow development and pressure drop calculations. There are unresolved questions regarding the impact of the orifice length on the pressure drop.
