Pressure formula and infinitesimal
The discussion centers on the pressure formula in classical physics, defined as P = dF⊥ / dS. Participants clarify that dF⊥ represents the infinitesimal change in force corresponding to a change in surface area (dS). They emphasize that when pressure remains constant, a decrease in surface area results in a proportional decrease in the force, as pressure is defined as force per unit area. The total force is derived by integrating pressure over the surface area.
  • Understanding of classical physics principles
  • Familiarity with calculus concepts, particularly infinitesimals
  • Knowledge of the relationship between force, pressure, and area
  • Ability to perform integration in mathematical contexts
  • Study the derivation and applications of the pressure formula in fluid mechanics
  • Explore the concept of infinitesimals in calculus and their physical interpretations
  • Learn about integration techniques relevant to calculating forces over varying surfaces
  • Investigate real-world applications of pressure in engineering and physics
Students of classical physics, educators teaching physics concepts, and professionals in engineering fields who require a solid understanding of pressure and force relationships.
Aleoa
I'm studing classical physics and I'm stuck with the simple pressure formula defined as:
P=\frac{dF_{\perp }}{dS}
Now, i know some calculus and the concept of infinitesimal in physics; however what i don't understand is :
1) according with the fact that in Calculus dF_{\perp } represent an infinitesimal change, it's an infinitesimal change from which quantity ?
2) If we obtain a constant value for the pressure, this means that the dF_{\perp } decreases as i take smaller dS (according with the definition of limit ) . Why the force decreases as the surface decreases ?
It is the change in the force if you change the area.
Because you have assumed constant pressure. Pressure is force per area. If you have the same pressure but double the area, the force will be twice as large.
But the force is defined point to point ?
No, it is the total force. You integrate the pressure over the surface to obtain the total force.
  • · Replies 69 ·
  • · Replies 30 ·
  • · Replies 76 ·
12K
30K
  • · Replies 31 ·
  • · Replies 30 ·
