Pressure rise due to heat in a tire
The discussion revolves around the potential causes of two bicycle tires popping, specifically examining the role of temperature changes and external pressure applied to the bike seat. Participants explore the physics of gas expansion in relation to tire pressure and the mechanics of tire failure.
  • Meta-discussion
  • Some participants suggest that the increase in temperature from 67°F to 101°F could lead to a significant rise in tire pressure, potentially contributing to tire failure.
  • One participant calculates that the pressure in the tire could increase by about 6% due to the temperature rise, questioning whether this is sufficient to cause a tire to pop.
  • Another participant argues that applying pressure to the bike seat does not significantly increase tire pressure, as it mainly deforms the tire rather than compressing the air inside to a dangerous level.
  • Concerns are raised about other factors that could lead to tire failure, such as pinching of the inner tube, debris inside the tire, or improper tire sizing.
  • Some participants express skepticism about the likelihood of both tires popping simultaneously due to the described circumstances.
  • A later reply emphasizes the importance of inspecting the tires and rims to establish a factual basis for the conclusions drawn by the school.
Participants generally agree that temperature and pressure play a role in tire integrity, but there is no consensus on whether the actions described could realistically lead to both tires popping. Multiple competing views remain regarding the mechanics of tire failure and the impact of external pressure.
Limitations include the lack of detailed inspection results of the tires and rims, which could provide further insight into the cause of the failures. The discussion also reflects varying levels of understanding of the underlying physics concepts.
Individuals interested in bicycle mechanics, physics of gases, and tire safety may find this discussion relevant.
I am stupid
I am not smart enough to know the answer to this question. My son is being accused of touching a bike yes touching on the seat a bike on a bike rack which the school is claiming made both tires pop. The only way i see this as possible is if the bike owner aired the tires up in the morning around 7:30 am with the out side temp at 67 degrees and by 3:45 the temp outside was 101 degrees . Is it possible that the air expanded enough from say 40psi at 67 degrees at 7:30 am to cause both tire to pop when a small amount of weight was applied . How much would the air in a tire expand with a 33 degree rise in temp at a starting point of 40psi at 67 degrees. Sorry so long winded . Thanks for any help .
Science news on Phys.org
Hi, uh, I am stupid! Welcome to PF! (I hope you choose your user name with tongue in cheek; after all, we are all here to learn more about physics.)
It is plausible that a higher temperature played some part in the tires popping. Gases that aren't confined do expand with increasing temperature, and this tendency would increase the stress on the tire material. However, it's impossible to say how close this extra load brought the tires to failure, since failure could also be promoted by nicks in or wear on the tube material -- along with someone possibly pushing down on the seat.
Yes it was tongue and cheek. I do not know a lot about Physics. I agree that the tire and other factors had to have played a part. Two tires do not just pop because some one touched a seat not going to happen. I think the tires where aired up past the normal operating pressure range in the morning so that they could get to school and by the after noon the extra pressure, the heat with my son was the straw that popped the tires.
No big deal the whole thing just does not feel right and that's why i ask poeple who know more about this stuff than i do. Now if you need your plumbing repaired I am your Master Plumber .
Thanks for your reply and help
"PV= nRT" where T is measured in "kelvins" (degree size the same as celsius but "0" is absolute 0"). 67 degrees Fahrenheit is 293 degrees kelvins and 101 degrees is 311 kelvins. So,initially, you have PV= (nR)293 and then P'V= (nR)311 (I am using P and P' for the different pressures but V, n, and R stay the same). So
\frac{P'V}{PV}= \frac{P'}{P}= \frac{(nr)311}{(nr)293}= \frac{311}{293}= 1.06/.
That is, the pressure in the tire, because of the increased heat, increases about 6%. No, that is not going to pop the tire.
Thank you very much . I am going to see the video myself monday. I Just don't get 2 tires popping because the seat was touched. Is that not what you are supposed to do to a bike seat is apply pressure while riding which should far exceed the pressure my son could apply with his hand. How ever i do see the math and your point and that is what i ask for Thank you for your time . Have a great Night.
Applying a force to the bike seat will not increase the pressure of the tires by any significant amount. What it does is deform the shape of the tires to increase the area in contact with the ground (force = pressure x area). The only change in pressure would come from the change in volume of the tire as it is deformed, and that is very small.
FWIW you son could easily apply more than his body weight to the seat with his hands, assuming he can push down hard enough lift himself off the ground.
I guess the moral of the story is...
If it's not yours, don't touch it.
I ask for an answer. Not a smart a#$ statement.
I thank all the people who gave answers to the question. To all the ones with opinions. Opinions are like butt holes we all have them and they all stink.
Please close the thread.
You're not going to pop a bicycle tire simply by touching the seat, nor by putting a lot of weight on the seat.
What will pop an innertube is the tire or the rims. If the innertube got pinched between the tire and the rim while uninflated (which usually happens because the innertube is the wrong size for the tire), then you have a pinched spot where the tire rim could easily puncture the innertube. Or, if there is debris inside the tire, inflating the innertube against the debris provides a point where the innertube could puncture. Or, if there is no rim tape between the innertube and the rim and the rim is damaged, the spokes can unseat from the rim and puncture the tube (of course, the punctured inner tube is the least of the problems, since innertubes are much cheaper than a new wheel).
Still, the chances of this happening on both tires at the same time is pretty remote. Wrong size innertubes would increase the chances (just based on the probability the owner installed the same size innertubes on both tires), but I still wouldn't expect both to pop at the same time. The video should be very interesting.
I would ask the school what their inspection of the tires and rims revealed about the failure.
No inspection...
no fact based conclusions??
No cause and effect established?
Is that how they teach?
  • · Replies 21 ·
  • · Replies 67 ·
