Thanks for answering.
lavinia said:
Do you mean a connection on a principal bundle?
Yes.
What do you mean by "tensorial character"?
That it doesn't depend on the choice of a frame because is defined on the fiber bundle rather than on the base manifold.
What is a trivial connection?
One with vanishing curvature form.
"group bundle"? What is that?
Sorry I meant to write the fiber, that in principal bundles is the Lie group.
Not sure what you are asking here.Can you give an example?
Ok. First, actually upon some further reading I realized the answer to the the first question is obviously negative, because the principal connections are constructed in such way that they cannot determine the triviality or nontriviality of the bundle in any direct way. Not to mention the fact that a principal bundle can have many different connections and curvature forms.
But maybe even if it is not the case that nontrivial connection can cause nontriviality of the principal bundle, maybe I can salvage the second question a bit.
I'll try and give some context. There is a theorem that says: "Given a fibre bundle with base space X and structure group G, if either X or G is contractible then the bundle is trivial."
And it ocurred to me that if the principal connection(aka Ehresman connection) generalizes the usual connection forms defined on the base manifold(and frame dependent) by being defined on the principal bundle itself, it might make sense that a situation could arise where the group structure in the fibre might restrict the possible base manifolds M in the principal G-bundle. Since a fiber bundle only demands the direct product locally, I think it make sense to consider also the discrete topology for the base manifolds. In this way when confronted with a nontrivial connection we could choose either to have a discrete manifold as base if we wanted to keep triviality at all costs or else a manifold with some topological feature like not being contractible that allowed the fiber bundle to be nontrivial in accordance with the topology of the group G.
I realize that in most situations(at least in physics) one uses a fiber bundle structure having in mind a specific base manifold(like a certain space or spacetime) so all this wouldn't apply in those cases. But I was thinking that sometimes one is only interested in certain local invariants like curvature that are realized in open set of a manifold and doesn't care about the manifold as a whole, and fiber bundles only care for the direct product of the fibre and the manifold locally.
Hope this is more readable and I have not ignored something important that makes my point useless.
