Probability of Even Score with 2 Tetrahedral Dice
  • Thread starter Thread starter scolty
    Dice
The discussion focuses on calculating the probability of obtaining an even score when rolling two tetrahedral dice, given that at least one die shows a 3. The user employs the conditional probability formula P(A|B) = P(A&B)/P(B), where A is the event of getting an even sum and B is the event of at least one die showing a 3. They initially calculate P(B) as 7/16 and P(A&B) as 3/16, leading to the final answer of 3/7. The user expresses confusion about the calculations and seeks clarification on the probabilities involved. The thread highlights the importance of understanding conditional probability in this context.
scolty
Hi,
im trying to figure out how to solve the following question and any hints would be greatly appreciated.
Question: Two tetrahedral dice, with faces labelled 1,2,3,4 are thrown and the number on which each lands is noted. The score is the sum of the two faces. Find the probability that the score is even, given that at least one die lands on a 3.
The final answer is suppose to be 3/7.
Below is as far as i had managed to get.
where:
A is the sum = an even number, ie 2nd dice = 1 or 3
B the first dice is 3.
if the above is correct (ie P(B) isn't the probability that a single dice is showing 3) then is 1/4, otherwise i think its 3/16 (that may be wrong.)
im lost from here on. As i mentioned earlier, any assistance would be appreciated.
i managed to solve this by writing out the sequence of dice rolls as follows:
(sure 99% of the ppl using this forum know more about stats than i do, so this is for the 1%)
green are the possible scenarios where one die is a 3.
red are the corresponding scenarios where the total is an even number
P(A|B) = P(A&B) / P(B)
where P(B) = 7/16 (note I am not entirely sure why its not 8 since 3,3 isn't counted as two possibilities.)
P(A&B) = 3/16 (See the combinations which are both green and red)
answer = 3/7
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
