Probability of forming a triangle
18 replies · 6K views · last reply
MarkFL
MHB
You have a thin rod of length $\ell$ and you cut it randomly into three pieces. Calculate the probability that the three pieces can form a triangle.
This sort of probability is a bit outside my usual comfort zone, but I'll have a go at it.
The length $\ell$ is immaterial, so I'll assume $\ell=1$.
Suppose that the cuts occur at $y$ and $x$, with $x,\,y$ independently uniformly distributed in $[0,1]$ and $x$ denoting the larger of them. We must have $x\geqslant1/2$ if the three segments are to form a triangle (because none of the sides can be greater than $1/2$). So one side on the triangle has length $1-x$. The difference between the other two sides must be at most $1-x$, and so $y$ must lie in the interval $\bigl[x-\tfrac12,\tfrac12\bigr]$, of length $1-x$ (see the picture). The probability of that happening (for a given $x$) is $\frac{1-x}x$. However, the probability distribution of $x$ (as the maximum of the two cut points) is not uniform, but has p.d.f. $2x$. So the overall probability of the three segments forming a triangle is $$\int_{1/2}^1 \frac{1-x}x\,2x\,dx = \Bigl[2x-x^2\Bigr]_{1/2}^1 = 1-\frac34 = \frac14.$$
(I hope that's right!)​
Clearly we can suppose without loss of generality that $\ell=1$. Setting $x_{1}$, $x_{2}$ and $x_{3}$ the length ot the three segments, the requested probability is the probability that none of the lengths of the segments is greater that $\frac{1}{2}$, i.e. ... $$P = \int_{0}^{\frac{1}{2}} \int_{\frac{1}{2}- x_{1}}^{\frac{1}{2}} \frac{1}{1-x_{1}}\ d x_{2}\ d x_{1} = \frac{1}{2}\ \int_{0}^{\frac{1}{2}} \frac{x_{1}}{1 - x_{1}}\ d x_{1} = |- x_{1} - \ln (1-x_{1})|_{0}^{\frac{1}{2}} = - \frac{1}{2} + \ln 2 = .19314718...$$ Kind regards $\chi$ $\sigma$
(Clapping) Your result is correct, but I have used a pre-calculus method to solve the problem which I will post within 24 hours, to give a few others a chance to write a solution.
I appreciate seeing a more advanced technique! (Yes)
Because a different solution with different result has been proposed the 'mental construction' I followed has to be explained with the scope to identify my error... If $x_{1}$ is the first segment and we suppose it uniformely distributed in $[0,1]$, then $x_{2}$ is uniformely distributed in $[0,1 - x_{1}]$. The condition that $x_{1}$, $x_{2}$ and $x_{3}$ are the sides of the triangle means that none of them exceeds $\frac{1}{2}$ so that we are searching the probability that $\frac{1}{2} -x < x_{2} < \frac{1}{2}$ conditioned by the probability that $x_{1} = x < \frac{1}{2}$ ... Kind regards $\chi$ $\sigma$
My 'error' has been that, setting $\xi_{1}$ and $\xi_{2}$ the coordinates of the first and second selected point, I have considered only the case $\xi_{1}<\xi_{2}$ and the computed probability is...
$$P_{1} = - \frac{1}{2} + \ln 2\ (1)$$
Now if we consider also the case $\xi_{1}>\xi_{2}$ we compute the residual probability as...
$$P_{2} = \int_{\frac{1}{2}}^{1} \int_{x_{1}- \frac{1}{2}}^{\frac{1}{2}}\frac{1}{x_{1}}\ d x_{2}\ d x_{1} = \int_{\frac{1}{2}}^{1} \frac{1 - x_{1}}{x_{1}}\ d x_{1} = |\ln x_{1} - x_{1}|_{\frac{1}{2}}^{1} = \ln 2 - \frac{1}{2}\ (2)$$
... so that the final result is...
$$P=P_{1} + P_{2} = 2\ \ln 2 -1= .386294361...\ (3)$$
Kind regards
$\chi$ $\sigma$
chisigma said:
$$P = \int_{0}^{\frac{1}{2}} \int_{\frac{1}{2}- x_{1}}^{\frac{1}{2}} \frac{1}{1-x_{1}}\ d x_{2}\ d x_{1} = ... = - \frac{1}{2} + \ln 2 = .19314718...$$ Kind regards $\chi$ $\sigma$
You selected the same approach I did.
But shouldn't it be the following?
$$P = \frac {\text{sum favorable outcomes}}{\text{total sum possible outcomes}} = \frac {\displaystyle\int_{0}^{\frac{1}{2}} \int_{\frac{1}{2}- x_{1}}^{\frac{1}{2}} \ d x_{2}\ d x_{1}} {\displaystyle\int_{0}^{1} \int_{1- x_{1}}^{1} \ d x_{2}\ d x_{1}} = \frac 1 4$$
I must be missing something, because I thought you could always make a triangle out of any three lengths...
Really?
Good luck :p
Specifically the triangle inequality puts a lower bound on the minimum total length required of the two smaller sides in order to form a triangle. If the larger side has length L, then the two other sides must sum to a length strictly more than L in order to form a triangle (less than L and no triangle is possible, equal to L and the best you can do is a degenerate triangle with three colinear vertices).
In Euclidean space, anyway.​
Bacterius said:
Really?
Good luck :p
Yes, that's what I was missing. Serves me right for picturing triangles in my mind and manipulating them, rather than picturing different lengths haha.
- - - Updated - - -
Actually, I think I'm still right - you can form a triangle with any three lengths - it's just not guaranteed that the ends of your lengths will form the vertices :P
I apologize for the confusion I created yesterday [:(] and I do hope to be able to return 'on the right way'... We call $x_{1}$ and $x_{2}$ the sequencially selected r.v., both uniformely distributed in [0,1]. Once we have selected $x_{1}$ we have two possibilities... a) may be that $x_{2} > x_{1}$ with probability $1-x_{1}$ and in this case the probability that none of the segments is greater than $\frac{1}{2}$ is... $$P_{a}= \frac{1}{2}\ \int_{0}^{\frac{1}{2}} \int_{x_{1}}^{x_{1} + \frac{1}{2}} d x_{2}\ d x_{1} = \frac{1}{8}\ (1)$$
b) may be that $x_{2} < x_{1}$ with probability $x_{1}$ and in this case the probability that none of the segments is greater than $\frac{1}{2}$ is... $$P_{b}= \frac{1}{2}\ \int_{\frac{1}{2}}^{1} \int_{x_{1} - \frac{1}{2}}^{x_{1}} d x_{2}\ d x_{1} = \frac{1}{8}\ (2)$$
Combining a) and b) we have...
$$P = P_{a} + P_{b} = \frac{1}{4}\ (3)$$Kind regards $\chi$ $\sigma$
Like everyone else, I observed that without loss of generality, we may let the rod be of unit length.
Let $x$ be the length of the first piece, $y$ be the length of the second piece, then $1-(x + y)$ will be the length of the third. We know we must have:
$$0<x<1$$
$$0<y<1$$
$$0<1-(x + y)< 1$$
Graphing these 3 inequalities, we find that we may represent the total sample space $S$ by the area bounded by the lines:
$$ x=0$$
$$y=0$$
$$x+y=1$$
which is a right isosceles triangle of area $$A_S=\frac{1}{2}$$. Each point in $S$ represents a possible partitioning of the rod. This area is shaded in red:
By the triangle inequality, we know all of the pieces must be less than 1/2 unit in length:
$$0<x<\frac{1}{2}$$
$$0<y<\frac{1}{2}$$
$$0<1-(x+y)<\frac{1}{2}$$
Graphing these 3 inequalities, we find that we may represent these conditions by the area $T$ bounded by the lines:
$$x=\frac{1}{2}$$
$$y=\frac{1}{2}$$
$$x+y=\frac{1}{2}$$
which is a right isosceles triangle of area $$A_T=\frac{1}{8}$$. Each point in $T$ represents a partitioning in which a triangle may be formed. This area is shaded in green:
Thus, the probability in question is:
$$P(\text{triangle is possible})=\frac{A_T}{A_S}=\frac{1}{4}$$
  • Plot of a right isosceles triangle filled in red, with vertices at (0,0), (1,0) and (0,1), on axes x from 0.0 to 1.0 and y from 0.0 to 1.0.
  • Plot of the unit square region with x from 0 to 1 and y from 0 to 1, with the triangle x + y < 1 shaded red and a smaller green right isosceles triangle inside it bounded by x = 0.5, y = 0.5 and x + y = 0.5.
can i ask why the pdf of x is 2x?
The key here is that x is defined to be the maximum of the two cuts. Since we have two (probabilistically) independent cuts, each with a uniform pdf, their maximum will have a pdf of 2x.
For my own sake, I will try to put together (and post) a more formal argument for the above statement. It agrees with my intuition, but requires probing.
thanks a lot :D I am new
This comes from a neat little trick I picked up in probstats, which I'm glad I found useful enough to remember.
Suppose that u and v are taken to be two independent cuts, each with a uniform distribution. We then take the definitions $x:=max\{u,v\}$ and $y:=min\{u,v\}$. Now, I will state that for any $t\in[0,1]$, we have:
$$P(x\leq t) = P(u\leq t)\, P(v\leq t) = (t)(t) = t^2$$
Note that the above holds because u and v follow independent uniform distributions over $[0,1]$.
From there, by the definition of a probability distribution, we have
$$\int_0^t pdf_x(x)\,dx = t^2$$
Now for the clever bit: we differentiate both sides with respect to t, applying the fundamental theorem of calculus. Doing so gives us
$$pdf_x(t)=2t$$
as desired.
The pdf for a uniformly distributed variable on the unit interval is the constant function $1$. The cumulative distribution function (cdf) is the integral of the pdf, namely the function $x$. The rule (which I don't know how to prove, not being a probabilist) is that for the maximum of two independent random variables, you multiply the cdf's. In this case, that gives you $x^2$ for the cdf of the max. You then differentiate the cdf to get the pdf, so that is where the $2x$ comes from.
Edit. Sorry, didn't see that TheBigBadBen had already answered this.
I probably can't pronounce myself a probabilist, but the following is probably true.
Suppose $Z=\max(X,Y)$ with independent $X$ and $Y$, then:
$$P(Z \le z)=P(X \le z \wedge Y \le z)=P(X \le z) P(Y \le z) \qquad \blacksquare$$
