MHB What is the probability that the second screw is also good?
  • Thread starter Thread starter sreeram
    Probability
The probability that the second screw is also good, given that the first screw is good, depends on the source of the screws. If both screws are from the same factory, the probabilities of defects are 5% for factory A and 1% for factory B. The discussion highlights the ambiguity in whether the screws come from the same factory or different ones, impacting the calculations. If both screws are from the same factory, the probability of the second screw being good can be derived from the first screw's condition. Clarification on the source of the screws is essential to accurately determine the probability.
sreeram
Question: All the screws in a machine come from the same factory but it is as likely to be from A as from factory B. The percentage of defective screws is 5% from A and 1% from B. Two screws are inspected and the first is found to be good. What is the probability that the second is also good?
My attempt:
G1: First screw is good. G2: Second screw is good
G1A: First screw comes from A. G1B: First screw comes from B
G2A: Second screw comes from A. G2B: Second screw comes from B
P(G1A)=1/2, P(G2A)=1/2, P(G1B)=1/2, P(G2B)=1/2
P(G1A $\cap$ G2A)=P(G1B $\cap$ G2B)=P(G1A $\cap$ G2B)=P(G1B $\cap$ G2A)=1/2*1/2=1/4
Now,
P(G1)=P(G1|G1A)P(G1A)+P(G1|G1B)P(G1B)
P(G1 $\cap$ G2)=P(G1 $\cap$ G2|G1A $\cap$ G2A)P(G1A $\cap$ G2A)+P(G1 $\cap$ G2|G1B $\cap$ G2B)P(G1B $\cap$ G2B)+P(G1 $\cap$ G2|G1A $\cap$ G2B)P(G1A $\cap$ G2B)+P(G1 $\cap$ G2|G1B $\cap$ G2A)P(G1B $\cap$ G2A)
P(G2|G1)=P(G1 $\cap$ G2)/P(G1).
Our teacher's answer:
A: Screw is from factory A B: Screw is from factory B
P(A)=1/2, P(B)=1/2
P(G1)=P(G1|A)P(A)+P(G1|B)P(B)
P(G1 $\cap$ G2)=P(G1 $\cap$ G2|A)P(A)+P(G1 $\cap$ G2|B)P(B)
Now P(G2|G1)=P(G1 $\cap$ G2)/P(G1).
Which answer is correct?
Mathematics news on Phys.org
Your explanation of the situation is a bit ambiguous. You say "2 screws are defective". Are they from the same lot, both from A or both from B, or not? If not, the fact that the first screw was defective is irrelevant! if 5% of the screws from A and 1% of the screws from B were defective and a screw is as likely to be from A as from B, then the probability a screw chosen from the whole lot is defective is (0.05+ 0.01)/2= 0.03, regardless of whether the previous screw was defective or not. (Unless there is a given small number of screws in A and B but you didn't say how many screws were in each lot.)
If, instead, both screws are from group A or both from group B, then the point of saying that the first screw was defective would be to give a probability that the second screw was from group A or B. Imagine 2000 screws, 1000 from A, 1000 from B. Of the 1000 screws from A, 5%, 50, are defective. Of the 1000 screws from B, 1%o, 10, are defective. That is a total of 60 defective screws 50 from A and 10 from B. Given that a screw is defective, the probability it is from A is 50/60= 5/6 and the probability it is from B is 10/60= 1/6. Given that the first screw was defective, the probability it was from A is 5/6 and in that case, the probability the second screw was defective is .05. The probability the first screw is from B is 1/6 and, in that case, the probability the second screw is defective is 0.01. In this scenario, given that the first screw is defective, the probability the second screw is as also defective is (5/6)(0.05)+ (1/6)(0.01)= 25/600+ 1/600= 26/600= 13/300 which is approximately 0.043.
Thanks for correcting my mistake. I assumed that one of the screws can come from A and another can come from B. My teacher assumed that both screws are either from A or from B.
I found out the following:
P(G1 ∩ G2)=P(G1 ∩ G2|G1A ∩ G2A)P(G1A ∩ G2A)+P(G1 ∩ G2|G1B ∩ G2B)P(G1B ∩ G2B)+P(G1 ∩ G2|G1A ∩ G2B)P(G1A ∩ G2B)+P(G1 ∩ G2|G1B ∩ G2A)P(G1B ∩ G2A)
=$1/4*(P(G1A)+P(G1B))^2$
P(G1)=1/2*(P(G1A)+P(G1B))=1/2*(P(G2A)+P(G2B))
P(G2|G1)=1/2*(P(G1A)+P(G1B))
Therefore P(G2|G1)=P(G1)=P(G2), as you pointed out.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
