Probability of picking fish from a tank
  • Thread starter Thread starter ecesiu
    Probability Tank
The problem involves calculating the probability of selecting at least half male guppies from a tank containing an equal number of male and female guppies when 15 fish are randomly selected.
  • Participants discuss calculating the probability using combinations and the distribution function, with one suggesting the use of complementary probabilities to simplify the calculations.
Some participants have offered insights into the calculation methods, including the potential to use complementary probabilities to reduce the number of calculations needed. There is an ongoing exploration of different approaches without a clear consensus on a single method.
Participants note that the problem may involve lengthy calculations and question the efficiency of the proposed methods. There is also mention of specific values that may be zero, which could influence the calculations.
ecesiu
a fish tank contains 12 male and 12 female guppies what is the probability that at least half of male will be selected if 15 fish are randomly selected and removed from the tank??
i am tried to find the probability as following :
P(at least 6)=P(6)+P(7)+P(8)+P(9)+P(10)+P(11)+P(12)
=(12c6)(12c6)/(24c15) + (12c7)(12c5)/(24c15)+...+(12c12)(12c3)/(24c15)
it seems to be a very long solution is there any way to solve it using the distribution function
Some problems just need a long solution; this is one of those. You ARE using the distribution function---that is exactly how you would compute it!
RGV
Also you might want to calculate the probability that LESS than half are chosen, since
P(0,1,2) are all zero. So you only need to calculate three values instead of 7.
thank you very much Ray Vickson , hgfalling it really nice idea to take the complement thanks
