Probability - transformation of a random variable
The discussion revolves around the transformation of a random variable, specifically focusing on the quantization of a standard normal distribution through a defined function. Participants are exploring the implications of this transformation on the resulting distribution of the new variable Y.
  • Participants discuss the lack of an inverse for the transformation function and consider how to specify the distribution of Y. Questions arise about the intervals for X that correspond to specific values of Y and the appropriate use of cumulative distribution functions.
Several participants are engaged in clarifying the nature of the distribution of Y, with some suggesting that it should be defined over integers only. There is an ongoing exploration of how to compute probabilities for specific values of Y, and some guidance has been offered regarding the intervals to consider.
Participants note the constraints of the problem, including the requirement to specify a finite list of integers for which the density of Y is non-zero and the implications of the continuous nature of X versus the discrete nature of Y.
dizzle1518
In an analog to digital conversion and analog waveform is sampled, quantized and coded. A quantized function is a function that assigns to each sample value x a value y from a generally finite set of predetermined values. Consider the quantized defined by g(x)=[x]+1, where [x] denotes the greatest integer less than or equal to x. Suppose that x has a standard normal distribution and pit Y=g(x). Specify the distribution of Y. Ignore values of Y for which the probability is essentially zero.
Going by how the book taught it I would start this problem by computing the inverse of g(x). However this function has no inverse. Any suggestions how to proceed?
What's the probability that Y = 1? For that to happen, X must be in [0,1). You can compute the probability of X being in that interval by using the normal distribution.
thanks. looks to me like the interval would be (-infinity, y-1). so the distribution of why would be [tex]\Phi(y-1)[/tex]. is this right?
Are you taking about the interval to use when computing the cumulative distribution of Y? Yes, that's right if you're using [tex]\Phi[/tex] to denote the cumulative normal.
The wording of the problem indicates that you should specify a finite list of integers on which the density of Y is non-zero.
i think it just asks for the distribution of Y. How would you know which integers to specify anyway?
I e-mailed my teacher and she replied with the below:
"No, for every y the corresponding interval for x has to be (-infinity,[y]). The endpoint should be an integer."
Does she mean it should be Fy=phi(y)??
There can't be that many integers with a significant probability. The standard normal has standard deviation = 1. There isn't much chance of getting Y = 12.You didn't say what you asked your teacher, so I don't what her answer meant.
got you. then picking up to what numbers you want to define the distribution of Y is up to the person solving the problem?
i asked her the same thing, i.e. if the interval was (-infinity, y-1) and if the distribution of Y is phi(y-1), and that's what she answered
It's up to them to do the work. There won't be much disagreement on which integers have non-zero probability if they all use similar tables of the normal distribution.
The phrase "if the interval was (-infinity, y-1)" isn't a complete sentence. So I assume she ignored it.
The answer to "if the distribution of Y is phi(y-1)" is no. She answered correctly. The distribution of Y isn't defined on all real numbers, only on integers. Her answer indicates that you only use the calculation on integer values of Y.
so what would be the distribution of Y then?
In my opinion, you are trying to give an abstract answer to a problem that wants you to do some numerical work. It wants a list of integers and their probability of occurrence. Are you in doubt about how to compute the numerical probability that Y = 1 or Y = -1 ? I think the problem wants you give the probability density for Y, not the cumulative distribution.
You have the correct idea about using [tex]\phi[/tex]. It's the imprecision in your statement of that idea that your teacher objects to. However, I don't think stating the formula for the cumulative distribution of Y is what the problem requests.
a bit yes
would Y have a density or mass function? i thought mass since Y is defined over integers only. the fact that X is continuous and Y discrete is throwing me off somewhat.
Y =1 exactly when X is between 0 and 1. What's the probability that the normal random variable X with mean 0 and standard deviation 1 is between 0 and 1? (It's about .3413.) The answer to that gives you the probability that Y = 1.
  • · Replies 30 ·
