Homework Helper
- 13,438
- 8,114
The needle has mass and is damped. Undamped needles bounce. A torque that acts on such a needle will not result in an instantaneous change in the needle's position. What the speedometer shows is some sort of approximate weighted average of past velocities.Mark44 said:Sure you can, and speedometers do exactly this. One kind of speedometer on a motorcycle I own has a gear driven sensor on the front wheel. The sensor has a worm gear that turns when the wheel turns. The worm gear drives a cable, the other end of which causes a magnet to rotate that in turn causes a needle to sweep to a certain position that corresponds to the speed of the motorcycle (speed = magnitude of velocity). Another motorcycle I have has a cable that comes from the transmission that drives the speedometer in a similar way. These measured values are the instantaneous speeds.
