Problem involving complex numbers
The discussion centers on solving a problem involving complex numbers and determinants. The initial equation derived from the determinant expansion is cw^2 + bw + a - c = 0, leading to the conclusion that for the determinant to equal zero, the imaginary parts must cancel. This analysis results in the relationship a = 2b = 2c. The solution set is identified as a straight line, including points like (0,0,0), (1,2,2), and (2,4,4). The geometric interpretation of the solution set is confirmed as a linear relationship.
ubergewehr273
Refer given image.
Expansion of determinant.
w^2+w+1=0 where w is cube root of 1.
Expanding the determinant I got cw^2+bw+a-c=0. Well after that I have no idea how to proceed.
ubergewehr273 said:
Refer given image.
If the determinant is going to be zero then the imaginary parts must cancel. What does that tell you?
I compared the real and imaginary parts separately and ended up with the relation a=2b=2c.
Ok, so what does that tell you about the geometry of the solution set?
Solution set includes (0,0,0) , (1,2,2), (2,4,4) and so on. This then gives a straight line. Thanks :bow:
Correct! You're very welcome.
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 18 ·
