Calculating Angle of Refraction Using Snell's Law
  • Thread starter Thread starter hardwork
    Law Snell's law
The discussion focuses on calculating the angle of refraction using Snell's Law for a ray of light transitioning through different media with varying refractive indices. The initial calculations led to confusion regarding the correct angle of incidence, with the user initially using the wrong angle. After clarification, the correct approach involved using sin 35 degrees for the angle of incidence, resulting in an angle of refraction of 18.2 degrees in the solid and 20.9 degrees in the liquid. The final calculations confirmed the correct angles after applying Snell's Law appropriately. The user successfully resolved their confusion and arrived at the correct solution.
hardwork
The figure (http://i43.tinypic.com/2dt5e2e.jpg") shows a ray of light traveling through a gas (n = 1.00), a solid (n = 1.84), and a liquid (n = 1.61). What is the angle θ made by the ray as it enters the liquid?
(n1)(sin θ1)=(n2)(sin θ2)
(1.00) (sin 90-35) = (1.84) (sin θ)
θ = 26.4 degrees
(1.84) (sin 26.4) = (1.61) (sin θ)
θ = 30.5 degrees
This is wrong. The angle of incidence is the angle made on the incident ray with the normal.
Would I just use sin 35 then? I'm confused. :frown:
yes.
Thanks! I'll try it again:
(1.00) (sin 35) = (1.84) (sin θ)
θ = 18.2 degrees
(1.84) (sin 18.2) = (1.61) (sin θ)
θ = 20.9 degrees
It is correct.
9K
9K
