MHB Problem with linear differential equation
stripedcat
Still learning the formatting commands, sorry!
I'm aware of the $(dy/dx) + P(x)y=Q(x)$ formula, as well as the $e^{\int P(x) dx}$ formula needed to get the "I" factor.
Here's the equation.
$$(dy/dx)+(2/x)y=3x-5$$
The "$P(x)$" would be $(2/x), \int 2/x\ dx = 2 \ln(x), e^{2 \ln(x)} = x^2$, so $x^2$ is the "I factor", and I know this gets multiplied by both sides
$$x^2((dy/dx)+(2/x)y=x^2(3x-5)$$
$3x^3+5x^2$ simplification on the right.
I'm not sure what to do with the left side. I know I need to get that dx out of there so it can go over to the right.
I think I need to start isolating the dy/dx expression...
$$x^2((dy/dx) = (3x^3+5x^2)-((2/x)y)$$
$$dy/dx = ((3x^3+5x^2)-((2/x)y))/x^2$$
This doesn't seem right at all.
The x^2 is an integrating factor. So the left hand side is now in a form that you can write:
[math]\frac{d}{dx} \left ( x^2 y \right ) = 2x y + x^2 \frac{dy}{dx}[/math]
Thus your original equation is now
[math]\frac{d}{dx} \left ( x^2 y \right ) = x^2 (3x - 5)[/math]
How do you finish this?
-Dan
-Dan
Yes, I was just looking at this. I didn't know about making it into d/dx and yanking the y out to multiply by the I factor. Give me a minute and I will edit this post with what I come up with.
EDIT: And here's what I came up with
Integrate both sides will cancel the d/dx.
$$x^2y=\int 3x^3-5x^2$$
I don't know the command for 'something over something', I was guessing on the integral symbol
$$x^2y=(3x^4/4)-(5x^3/3)+C$$
How's that?
EDIT: Yes I know, it keeps going after that in order to get just the y
\frac{}{} gives the fraction template. You type whatever you want in the numerator in the first set of curly brackets, and whatever you want in the denominator in the second set of curly brackets.
How's that?
Looks good to me. :)
-Dan
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
