Problem with polynomials and spheres
markcholden
Hi all,
I've got this problem:
Code:
Consider the points P such that the distance from P to A(-1,5,3) is twice the distance from P to B(6,2,-2). Show that the set of all such points is a sphere, and find its center and radius.
I think the setup should be this:
Code:
sqrt[(x+1)^2 + (y-5)^2 + (z-3)^2] = 2*sqrt[(x-6)^2 + (y-2)^2 + (z+2)^2]
But when I try to work it out, I just end up with a mess and no equation for a sphere. Any help appreciated.
Mathematics news on Phys.org
Don't use "code" tags like that - it makes people have to scroll to read your problem/solution. Anyways, square both sides, move everything to the left side, complete the square in each of x, y, and z, and take the constant numbers left over from completing the square over to the right side, and express the right side as a square. You'll end up, then, with something of the form:
(x-a)2 + (y-b)2 + (z-c)2 = r2
from which you can easily read off the center and radius.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
