How Do I Properly Connect an LM117t 3.3V Voltage Regulator?
The discussion focuses on connecting the LM117T 3.3V voltage regulator, with users highlighting the importance of consulting the datasheet for correct pin configurations. It is noted that the LM117T is an adjustable regulator, and the output voltage is determined by a resistor divider connected to the reference input. There is confusion regarding whether the original poster meant to reference the LM1117 instead, as the pin configurations differ significantly. Users suggest verifying circuit connections and component orientations to avoid damage to the regulator. Proper understanding of the regulator's specifications is crucial for successful implementation.
Tesladude
So I need to use this LM117t 3.3v voltage regulator and I asumed the pins were the same as most regulators where you have in/ground/ and out. But it is not working that way, does anyone know the in and outs of this regulator or have an alternative?
hey t-dude :smile:
not its not ...
its never safe to assume anythig in electronics... always test, measure and in this case check the datasheet
LM117T-3.3
page 3 gives the pin out configuration for the various package forms
the output as you will see is the centre pin
hope that's helpful :smile:
cheers
Dave
lm117 is an adjustable regulator. It works by generating an output voltage such that the voltage at the reference input (what was ground in a fixed output regulator) reaches 1.25V. So it you have R1/R2 divider with equal values the output will go to 2.5V producing 1.25V at the "center" pin. If you connect the output to the reference input you will get 1.25V.
The datasheet that davenn linked to is for an LM1117 (different number, 3 1's) that is a family of fixed output regulators.
that's interesting as it was also saying 117 at that page
LM1117T-3.3 - LM1117 3.3V Low Drop-Out Voltage Regulator
Technical Information - National Semiconductor LM117T Datasheet
I wonder if the TD typoed and was meant to say LM1117t-3.3 and not the 117t-3.3 that he did ?
cuz he was pretty specific with the rest of the info. he wasnt referring to setting up an adj regulator huh
so I will stick with the info I gave till TD reports back in
MY BAD!
Lm1117t!
The datasheet also says ground output input and I just tried that and i am getting the exact same output as I have input (9v)
show me a pic of you circuit digram and also a pic of your actual construction
to see if you boo boo'ed :)
that V-reg is different pinned to the LM78xx series fixed regulators where the GND pin is the centre pin
Dave
those are the 2 ten caps shown in datasheet circuit
Hi TD
through the dark blurryness :wink: it looks ok
assuming you have put the electro caps in the correct way around ?
you didnt have this connected incorrectly originally did you ?
your opening comment
indicates you probably did. you may have damaged the regulator, do you have another one to try ?
Dave
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 16 ·
