MHB Is the Product of Real Numbers Always Larger When Exponentiated?
NoName3
For any $a \in \mathbb{R}$, let $a^3$ denote $a \cdot a \cdot a$. Let $x, y \in \mathbb{R}$.
1. Prove that if $x < y$ then $x^3 < y^3$.
2. Prove that there are $c, d \in \mathbb{R}$ such that $c^3 < x < d^3$.
Hint for 1.: $y^3-x^3 = (y-x)(y^2 + xy + x^2)$. Now show that each of those two factors is positive.
Thank you.
Since $x< y$ we have $0<y-x$. So the first factor is positive.
$y^2 + xy + x^2 = (y+\frac{1}{2} x)^2+x^2- \frac{1}{4}x^2 = (y+\frac{1}{2} x)^2+\frac{3}{4}x^2 $
which is positive as well. Therefore if $x< y$ then $x^3 < y^3$ as required.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
