Product of two uniform random variables on the interval [0,1]
The discussion centers on finding the density function of the product of two independent uniform random variables, R1 and R2, defined on the interval [0,1]. The cumulative distribution function (CDF) approach is recommended, where the probability P(Z < w) is calculated by integrating over the area defined by the product xy < w in the unit square. The expected value of Z is confirmed to be 1/4, derived from the independence of R1 and R2. The conversation highlights the importance of understanding the relationship between independent variables and their distributions.
  • Understanding of uniform distributions, specifically on the interval [0,1]
  • Knowledge of cumulative distribution functions (CDF) and probability density functions (PDF)
  • Familiarity with integration techniques in probability
  • Concept of independence in random variables
  • Study the derivation of the cumulative distribution function for products of random variables
  • Learn about the properties of independent random variables in probability theory
  • Explore the method of transforming variables in probability distributions
  • Investigate the use of moment generating functions in finding distributions
Students and professionals in statistics, data science, and mathematics who are working with random variables and probability distributions, particularly those interested in the behavior of products of uniform distributions.
Absolut_Ideal
If R1 and R2 are two uniformly distributed random variables on the interval [0,1]. What is the density function Z=R1*R2?
I'm not sure actually
I have tried to manipulate with moment generating function (which i suspect is the method i should use) but I have not come up with anything good.
I know that since they are independent the Expected Value of Z should be 1/2*1/2=1/4. But I'm not sure if this will help me at all.
I'm really just looking for an answer to whether I should continue experimenting with moment generating function or if I should try a different approach to the problem. Currently, I have no idea where to even start. The book for the course does not provide any examples what so ever for these types of problems.
Thanks in advance!
When you add two distributions, the resulting distribution is their convolution.
Multiplying is the same as adding the logarithms, so...
A standard method to get the distribution of h(X,Y) for independent X and Y is to first get the cdf P{h(X,Y) <= w}, which you can get as
P\{ h(X,Y) \leq w \} = \int_{-\infty}^{\infty} P\{h(X,Y) \leq w | Y=y\} f_Y(y) \, dy, and to recognize that P\{h(X,Y) \leq w | Y=y\} = P\{h(X,y) \leq w \}, because X and Y are independent.
RGV
Oooh - I'd actually forgotten about that. Probably since all I've every had to do is either add or multiply distributions. Mostly add. Thanks.
Follow Ray Vickson's hint and determine the cumulative distribution function first: If R1 takes the values x, R2 takes the values y find the probability that z=xy < w: F(w)= P(z<w)
R1 and R2 are uniformly distributed. The (x,y) ordered pairs can be represented as points of the xy plane in the range 0<x<1, 0<y<1, and the probability of finding a point in a given domain is proportional to the geometric area. Draw the curve xy=w, and find the area where 0<x<1, 0<y<1, and xy<w (painted yellow in the picture).
ehild
Hmmmm... not told that X and Y are independent, or the range on which they are uniform.
Only need the density fn not the cumulative density.
What's wrong with taking the antilog of the convolution of the logs?
I think we now need to hear from OP.
We were told they are uniform on [0,1], but not that they are independent. Even though we want the density, sometimes the easiest way to get that is to differentiate the cumulative.
RGV
Gah! read that twice and missed it both times ... right: time to stop for the night!
Thanks a lot for the explanations guys! It helped me out a lot!
Cheers!
Cheers!
What have you got for the density function f(Z)?
ehild
  • · Replies 40 ·
