Efficient VB.NET Table Archiving: Move Records Between Tables Monthly
  • Thread starter Thread starter Keyur
    Programming
To move records from one table to another within the same Access database using VB.NET and the Jet OLEDB provider, an Append Query is required. This query allows for the addition of records from the source table to the destination table without deleting any existing records in the destination table. Once the Append Query is successfully created, it can be saved and executed on a recurring basis, such as at the beginning of each month, to facilitate the archiving process. The graphical user interface (GUI) of Access can assist in constructing this query.
Keyur
I have a table in access, it is linked to vb.net by jet oledb provider. I want to move all the records of this table to a new table which may already contain records. I have to move all the records of table 1 to table 2 at the 1st of every month. Table 2 may contain records, these should not be deleted.
Can anyone help with archiving of these records. Any help will be appreciated.
Technology news on Phys.org
To another table within the same access database?
Yes, the same access database.
The GUI can help you with this. You need what's called an Append Query. If you write this successfully, you can save it and re-run it anytime you want to.
Done with it.
THANK YOU ALL.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
