Projectile Motion and acceleration of particle
The discussion revolves around the motion of a particle in the X-Y plane with non-zero acceleration in both the X and Y directions. The original poster questions whether such a scenario can result in a parabolic path, as indicated by their textbook, which states the path is parabolic despite the dual acceleration.
  • Participants explore the implications of having non-zero acceleration in both dimensions and whether this guarantees a non-parabolic trajectory. Some suggest considering the nature of projectile motion and the forces acting on it, while others question the assumptions made about the constancy of acceleration and the possibility of using different coordinate systems.
The discussion is ongoing, with participants providing insights and asking clarifying questions. There is a recognition of the complexity of the problem, and suggestions have been made to consider alternative perspectives, such as rotated coordinate systems, to analyze the trajectory.
There is uncertainty regarding the textbook's assertion, with participants contemplating the possibility of a misprint. The original poster expresses confusion about the relationship between acceleration and the resulting path shape.
AkshayM
If a particle moves in X-Y plane with acceleration non zero in X and Y , the particle will not move in a parabolic path
True or False ?
X = UxT + 1/2(Ax)T^2
Y= UyT + 1/2 (Ay)T^2
The equation of trajectory that i came up with involved Y^2 , X^1/2 and X
I am not able to draw conclusions with it
So i guessed it to be True as for a parabolic path you need constant acc in only one axis and zero acc in other axis
But the book says false
Please help !
Welcome to the PF. :smile:
Think about how a projectile traces out a parabolic shape when you throw it up and out at a 45 degree angle. What forces and accelerations are acting on it in that situation (after it leaves your hand)?
Just the gravity pull and air friction
Good. So neglecting air friction (which will alter the path away from a pure parabola), in how many dimensions is the projectile accelerating while it traces out the parabola? :smile:
2 dimensional motion with downward acceleration (g)
@AkshayM -- You marked this thread as solved -- does that mean you understand now?
Sorry no bymistakely i did it
True or False ?
So the book is saying that the path is parabolic even when there is acceleration in 2 dimensions?
Yes it says parabolic path
Case of a misprint ?
Maybe. Can you ask the professor or a TA about it? Do you know any other students in your class who are also working on the problem?
True or False ?
Please help !
First, let us be clear that the question is asking whether a nonzero acceleration in both coordinates guarantees that it will not be a parabola. My point is nothing has been said about constancy of acceleration, so certainly it might not be a parabola.
So now suppose there is constant acceleration in each coordinate. What if you were to use different axes? Might there be a direction in which there is no acceleration? Will there always be such a direction?
To re-express the answer of haruspex in post #11: if you take the path to be ##x = v_x t + \frac{1}{2} a_x t^2## and ##y = v_y t + \frac{1}{2} a_y t^2,## (with constants ##v_x, v_y, a_x,a_y##) can you find a constant angle ##\theta## and a rotated coordinate system
$$\begin{array}{rcl}
X&=& x \cos(\theta) - y \sin (\theta)\\
Y&=& x \sin (\theta) + y \cos (\theta)
\end{array} $$ in which the new path has the form ##X = U_x t, \; Y = U_y t + \frac{1}{2} W_y t^2,## (with constant ##U_x, U_y, W_y##) or is that not possible? If it is possible, that would give you a "rotated" parabola.
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 35 ·
