Projectile motion with air resistance
This discussion focuses on modeling the trajectory of a projectile subject to air resistance, specifically using the drag force equation F_{\text{d}} = \frac{1}{2}C_{\text{d}}\rho\text{A}(v(t))^2. Participants explore the use of differential equations to derive velocity and position over time, with solutions leading to expressions such as v(t) = \frac{2m}{K_1 + C_{\text{d}}\rho \text{A}t} and x(t) = \frac{2m}{C_d \rho A}\ln\left(\frac{2m+C_d\rho A v_{0x}t}{2m}\right). The conversation also addresses the implications of drag on maximum height and trajectory, emphasizing the necessity of negative signs in force equations and the use of L'Hôpital's Rule for limits.
  • Understanding of differential equations, particularly in the context of motion.
  • Familiarity with drag force concepts and the parameters involved (C_{\text{d}}, \rho, A).
  • Knowledge of Newton's laws of motion and their application to projectile motion.
  • Basic calculus skills, including integration techniques and limits.
  • Research the derivation of projectile motion equations with air resistance using numerical integration techniques.
  • Study the application of L'Hôpital's Rule in resolving indeterminate forms in calculus.
  • Explore the differences between linear and quadratic drag force models in projectile motion.
  • Learn about parametric equations in the context of projectile motion and their applications in physics simulations.
Students and educators in physics, engineers working on projectile design, and anyone interested in the mathematical modeling of motion with air resistance.
matineesuxxx
Model the trajectory of a projectile with an initial velocity v_0 that is subject to the force of drag.
v_x(t) = v_{0x} + \int_{t_0}^t a_x(t')\mathrm{d}t'
I really have no clue how to tackle this problem. I'm sort of leaning towards the idea of a differential equation solution, however I only have a small amount of DE's under my belt from calc 2.
I have done a fair amount of searching online, however every page that I've seen about this problem assumes drag force is linearly dependent on speed, or even assuming drag is constant. Would I gain enough insight solving the problem in which drag force is linear to make headway on the real life scenario?
If you replace F in your first equation with one of Newton's laws, you get a differential equation with the velocity and its time-derivative.
You need to express acceleration as an equation. mfb gave you a hint for how to do this.
Then note that acceleration = dv/dt, but in this case, acceleration will be a function of velocity:
dv/dt = a(v)
to deal with this rearrange it to:
dv/a(v) = dt
then integrate both sides to get velocity versus time (don't forget to include a constant of integration after integrating). You'll need to repeat this process again and integrate to get position versus time.
Thanks a lot, both of you. It's been a while since I've done DE's, so I didn't see what now seems so obvious!
So I get,
F_{\text{d}} = -\frac{1}{2}C_{\text{d}}\rho \text{A}v^2 = m\frac{\text{d}v}{\text{d}t}
which then leads me to,
$$ v(t) = \frac{2m}{K_1 + C_{\text{d}}\rho \text{A}t}$$,
where K_1 = C_{\text{d}}\rho \text{A}mK_0 and K_0 is just the constant of integration.
when I use $$ x(t) = x_0 + \int_{t_0}^{t_1} \frac{2mv_{0x}}{C_d \rho A v_{0x}t + 2m}dt $$
to get my displacement vs time graph I get $$x(t) = \frac{2m}{C_d \rho A}\ln\left(\frac{2m+C_d\rho A v_{0x}t}{2m}\right) $$
but this reduces to 0, not x(t) = v_{0x}t if there is no drag. So is this correct, or have I made a mistake?
[edit] Sorry, I neglected to take a limit as c, p, or A went to zero
rcgldr said:
I'm thinking velocity should be:
$$ v(t) = \frac{1}{\frac{1}{v_0} - \frac{t}{C_{\text{d}}\rho \text{A}}}$$
Note that at t = 0, v = v0,and at t = ∞, v = 0.
Here's what I did:
let \mu = C_d \rho A so then -\frac{1}{2}\mu v^2 = m\frac{dv}{dt} \implies v\mu t = 2m - vK.
so v = \frac{2m}{\mu t + K}, where v(0) = v_{0x} \implies K = \frac{2m}{v_{0x}} so then I end up with $$ v = \frac{2mv_{0x}}{2m+\mu v_{0x}t} = \frac{2mv_{0x}}{2m + C_d \rho A v_{0x}t}$$
which still reduces to the correct equations when taking limits, and we don't have a nasty asymptote.
Sorry for the previous post, I wasn't paying attention to the fact that the force opposes velocity and should be negative: m dv/dt = -1/2 u v^2 . What you have looks correct.
If the drag is zero, then the integral using CdpA to produce x(t) is undefined as you end up with something in the form of (1/0) ln(1) => 0/0. So if CdpA == 0, the integral becomes:
$$ x(t) = x_0 + \int_{t_0}^{t_1} \frac{2mv_0}{0 + 2m}dt $$
$$ x(t) = x_0 + \int_{t_0}^{t_1} v_0dt $$
If the drag is zero, then the integral using CdpA to produce x(t) is undefined as you end up with something in the form of (1/0) ln(...). So if CdpA == 0, the integral becomes:
No worries, I actually forgot to add the negative sign in the first occurrence of the force equation, so i made the same mistake :). And in regards to the (1/0)ln(...), it ends up as 0/0 so just use L'Hopital's Rule and you still end up with x(t) = (v_0x)t, same goes for m -> infinity
matineesuxxx said:
Thanks for all the help! Here's a neat interactive graph I did up for it:
So you enhanced the equations to a 2d situation? I'm not sure I understand the graphs. I assume the graph shows the X Y plane with gravity exerting a force in the -Y direction and drag always opposing velocity (both x and y components), however the peak height reached in the graphs for the object remains the same regardless of drag. It appears the calculator adjusts the initial angle of velocity to do this, but it would seem that if drag is sufficiently large, the peak would be less than the zero drag case, even if the initial velocity was vertical.
The maximum height reached would not change given any air drag, so long as the drag force is purely horizontal, which is one condition of my problem, although I neglected to mention that. And you the graphs are a trajectory, horizontal vs vertical distance.
matineesuxxx said:
The maximum height reached would not change given any air drag, so long as the drag for is purely horizontal.
Ok, so an imaginary case where drag is only horizontal. I was expecting something like this:
http://demonstrations.wolfram.com/ProjectileWithAirDrag
It might be interesting to plot a postion versus time graph (straight line for zero drag non-zero velocity).
Yes. I wanted to originally have drag act as it really would, but I have no clue how to solve a differential equation of the form q(x) = \frac{dy}{dx} + p(x)y^2.
That wolfram article is using an imaginary drag factor that varies with velocity as opposed to velocity squared.
I though about parametric approach, but apparently the equations involve v and vx and vy:
$$ m\ \frac{dv_x}{dt} = - \ c\ v \ {v_x} $$
$$ m\ \frac{dv_y}{dt} = -m\ g \ - \ c\ v \ {v_y} $$
based on this pdf article that uses numerical integration to solve the problem:
topic01.pdf
If the object is falling vertically, then there's no x component, and the equations can be solved:
wiki free fall with air resistance .htm
Do it numerically.
  • · Replies 37 ·
