Projectile negative vertical displacement
12 replies · 2K views
rudransh verma
A ball is launched from a catapult with an initial speed of 3.25 m/s at an 61.7 degrees above the horizontal. If the basket is 93 cm away from the catapult horizontally where should the basket be placed vertically so the ball lands in the basket?
$$s= ut+\frac 12 at^2$$
I know how it’s done. So let’s jump on the question. The displacement that came was negative 6 cm. I want to know how this formula describes perfectly negative displacements.
I don’t understand the mechanism. If I assume ##ut## to be distance traveled in absence of g then what is ##-1/2gt^2## doing to ##ut## ?
Suppose you just let a stone drop. After time t, how far has it fallen? How would you write that as a vertical displacement, with up defined as positive?
Watch this demonstration. The gun is initially aimed at the monkey.
$$-s=ut-\frac12gt^2$$
Or
$$x-x0=ut-\frac12gt^2$$ where x<x0
Or
I specified "drop", so u=0.
The second equation is right, but the first has the wrong sign. If up is positive the displacement is given by ##s=-\frac 12gt^2##.
So do you understand what the ##-\frac 12gt^2## does? It takes the ut that operates without gravity and adds the effect of gravity.
But I may not have grasped what it is that bothers you.
O yes.
haruspex said:
If up is positive the displacement is given by s=−12gt2.
but s should be -ve since it’s going downwards. How is my first eqn wrong? But if I take -ve sign then it will get canceled by ##-\frac12gt^2## so s is now +ve. I don’t think I get it.
So can I say ##-\frac12gt^2## is a type of distance operator. Is ##ut## distance from origin and ##-\frac12gt^2## distance from where the v=0 to the final position of the body in free fall motion? When I take difference I get the distance between the initial and final position of body.
I generally get stuck on formulas on how they reveal the truth about the world around us.
This formula perfectly reveals the displacement as +,-,0 based on the time elapsed. How?
Right, and ##s=-\frac 12gt^2## will make s negative. But you had ##-s=-\frac 12gt^2##, which is the same as ##s=\frac 12gt^2##, and will make s positive.
So when do we take -##s##. I guess when it’s given and we are asked to find something else. But we don't have to take ##s## as -##s## when we have to calculate it. Right?
So when do we take -s.
I do not understand your question. The formula is ##s=ut+\frac 12 at^2##. It is not ##-s=ut+\frac 12at^2##. The result for s may be positive or negative , but the formula remains the same.
I mean when do we take -s. When we are given a value of s in a question and it says body falls down. When we need to find something else. Then we take s=-5 for example. But when we are to find s then we don’t assume it’s value as -s because that will produce wrong result.
We don't write -s because it is not -s. It is s, whether the value of s is positive or negative.
You are confusing the sign placed on the variable s with the sign of a value of s.
Ok 👍🏻
So can I say ##-\frac12gt^2## is a type of distance operator. Is ut distance from origin and ##−\frac12gt^2## distance from where the ##v=0## to the final position of the body in free fall motion? When I take difference I get the distance between the initial and final position of body.
