Projector in an arbitrary basis, howto compute?
keen23
Hello!
once again I got trouble with Dirac-notation:
Given an non-orthonormal basis. Measurement via the projection operator should not give an definit answer, in which state the system was due to the overlap. Geometrical that's clear, but I'm unable to compute that... :(
I tried it for the following states:
[tex]|\psi_0\rangle=|0\rangle[/tex]
[tex]|\psi_1\rangle=\frac{1}{\sqrt{2}}(|0\rangle+|1\rangle)[/tex]
My projector looks the following way (I am not sure about the coefficients):
[tex]P=|0\rangle\langle0|+\frac{1}{2} (|0\rangle+|1\rangle)(\langle 0|+\langle 1|)[/tex]
And now I am confused. When I plug state psi1 on both sides I get a sum of several 0s and 1s I don't know how to interprete.
Any hints? Thank you!
Does [itex]P^2 = P[/itex]? If it doesn't (I don't think that it does), then [itex]P[/itex] is not a projector.
Avodyne said:
What exactly are you trying to do?
I, too, would like to know the answer to this.
At the moment I am reading about general measurements and POVMs.
They say, that you can't definitely distinguish two non-orthonormal states by a "normal" measurement, meaning by a projection onto the states (since each has an overlap with the other).
(That's why you need the POVM to do that.)
I just would like to see the math.
Or is that the point, that I can't construct an projection-operator from my non-orthonormal states? But actually you can always project a vector onto its constructing basis vectors, no matter if they are orthogonal or not.
I hope this makes my confusion a bit clearer.
