Proof of \forall m \in \mathbb{Z} that -m=(-1)m
  • Thread starter Thread starter JoshSmith
    Proof
The discussion revolves around proving the statement \forall m \in \mathbb{Z} that -m=(-1)m, focusing on the properties of integers and their operations.
  • Participants present various proof attempts, questioning the validity of steps involving the distributive property and the definition of the additive inverse. Some express uncertainty about the uniqueness of the result.
Multiple approaches to the proof are being explored, with participants providing feedback on each other's reasoning. Some guidance has been offered regarding the use of axioms and the clarity of definitions, but no consensus has been reached on a single method.
Participants note the challenge of relying on unstated propositions and the need for clarity in definitions, particularly regarding the additive inverse and the properties of multiplication. There is also mention of the difficulty in navigating basic properties without skipping steps.
JoshSmith
Prove [tex]\forall m \in \mathbb{Z}[/tex] that [tex]-m=(-1)m[/tex]
The axioms of [tex]\mathbb{Z}[/tex] are assumed, as are some of its propositions and corollaries. They would be too many to retype here, so assume that I have referenced the correct axioms and propositions if those are not stated outright.
I believe, after working through it, that I got the solution. This has taken me hours, though, so please tell me if this works.
Proof. We'll show -m=(-1)m.
m=m by definition.
m+m=m+m by replacement.
m+m(1)=m+m by the multiplicative identity.
m+((-m)(-1))=m+m by some proposition not stated here.
(-m)(-1)=m by some proposition not stated here.
(-m)(-1)=m(1) by the multiplicative identity.
(-m)(-1)=m(-1)(-1) by some corollary not stated here.
-m=m(-1) by cancellation.
-m=(-1)m by associativity. Q.E.D.
how about this, not sure whether the distributive multiplication is ok
1 + (-1) = 0-----------------by def'n (addditive inverse)
(1+(-1))*m = 0*m = 0--------multiply by m
1*m + (-1)*m = 0-----------distributive multiplication
m + (-1)*m = 0 -------------1*m = m
---> -m = (-1)*m by def'n of -m
may need to show it is also unique, not sure
---> m = (-1)*m by def'n of -m
At the end I think you mean -m = (-1)m. You're missing a sign.
I don't think that works because we haven't defined -m, so you can't say it's by definition of -m. In fact, we're actually trying to define -m via this proof. Also, in the first step I think you'd need to be clear that 1+(-1)=0 is by the additive inverse, not by definition.
The whole thing is all very basic, I know. But does the proof I gave seem to work?
i find a lot of the basic stuff tricky, beacuse you're so used to skipping the steps you're so familiar with...
you're right about 1 + (-1) = 0 being the additive inverse property, and about the missing -
however the definition of -m is that
m + (-m) = 0
so as soon as you are at the step
m + (-1)*m = 0
you should be able to see it they are equivalent, i skipped the last steps
but to be a tiny bit more explicit...
m + (-1)*m = 0
m + (-1)*m + (-m) = (-m)....add (-m) to both sides
m + (-m) + (-1)*m = (-m)...commutative
(-1)*m = (-m).......defn of (-m)
QED
I like this a bit better as, i think it only relies on the basic properties:
- existence of additive inverse
- multiplicative distribution
- multiplicative identity & zero
- existence of (-m)
- addditive commutation
there are quite a few corollaries in yours, that i can't see where they came from
eg. in your 4th step you assume:
m*1 = (-m)*(-1) by some proposition not stated here
which is pretty close to what you're trying to prove...?
I find the basic stuff pretty tricky, too, which is why this was so difficult.
The 4th step is close, but not quite it. If you had the book I have (which lays out all these axioms and propositions) you'd see it. I'm not going to retype it all.
I do like yours better; it uses less steps and only axioms.
So, question for you: how did you know how to approach this? My question throughout has been whether an approach to proof can come from some general method, or whether such mathematical intuition is developed over time. I was only able to solve this by working backwards, but I feel there must have been an easier way.
not sure, i think its just an intuition thing you build up after working some examples, and some trial and error
i guess i thought, what's in what we want to prove.. m, (-m), and (-1), whilst 1 is always inherent... can get most of them involved by multyiplying 1+(-1) = 0 by m... Usually starting from zero can relate a lot of things as well
And actually i think for correctness, though the idea is the same, the first step should more be like
0 = 0*m = (1+(-1))*m = 1*m + (-1)*m = m + (-1)*m
and so on from there
I see what you mean. You just kind of pulled apart the individual components and worked your way up from there. Nice.
I don't think you actually have to lay out the steps nearly as much as you're saying in your reply. I'm pretty sure you had it down right the first (revised) time.
