Proof of ∏(√n) Increment for Centered Polygonal Numbers w/ Prime Index
  • Context: Graduate
  • Thread starter Thread starter JeremyEbert
    Index Prime Proof
The discussion revolves around the behavior of the prime counting function ∏(√n) in relation to centered polygonal numbers with prime indices. Participants explore the conditions under which this function increments, particularly focusing on the relationship between prime numbers and specific mathematical constructs.
  • Some participants assert that ∏(√n) increments only when n equals p², where p is a prime, while questioning the relevance of centered polygonal numbers to this increment.
  • Another participant clarifies that ∏(Floor(√n + 0.5)) increments only when n is a centered polygonal number with a prime index, suggesting that a proof should be straightforward.
  • One participant introduces an alternative function, ∏(1/2 + √n), noting that it jumps when n equals (p-1/2)², which simplifies to p² - p + 1/4, and states that for integer n, the jumps occur at p² - p + 1.
  • Another participant discusses the relationship between oblong (pronic) numbers and polygonal numbers, indicating that oblong numbers correspond to triangular numbers but questioning their general analogy to polygonal numbers.
  • One participant points out that while pronic numbers plus one yield centered polygonal numbers, the function ∏(1/2 + √n) does not provide insights about ∏ itself, deeming it trivial.
Participants express differing views on the relationship between the prime counting function and centered polygonal numbers, with some asserting specific conditions for increments while others challenge or refine these claims. The discussion remains unresolved regarding the precise connections and implications of these mathematical relationships.
Participants note the lack of precision in earlier statements and the need for clarity regarding the definitions and relationships between the various mathematical constructs discussed.
JeremyEbert
Is there a proof that ∏(√n) increments only when n is a centered polygonal number with a prime index?
∏(n) is the prime counting function
n=p^2-p+1 for a prime p
3, 7, 21, 43, 111, 157, 273, 343, 507, 813, 931, 1333...
http://oeis.org/A119959
The statement in your question is not very precise. Obviously, ∏(√n) increments exactly when n=p2, where p is a prime, and for no other n. But I suppose that is not what you are looking for, and I am curious to know what your centered polygonal numbers have to do with this.
Norwegian,
Sorry for the extreme lack of precision. I definitely forgot to include a key part while typing this up.
Obviously, ∏(√n) increments exactly when n=p2. However ∏( Floor(√n + 0.5) ) increments only when n is a centered polygonal number with a prime index. It seems like a proof of this should be pretty straight forward.
Hi Jeremy, if we instead look at ∏(1/2 + √n), this function jumps exactly when n=(p-1/2)2=p2-p+1/4. If we require n to be an integer, the jumps will indeed happen when n=p2-p+1.
Ah yes, the floor function is a bit redundant. Thanks for that.
This obviously relates then to the square root of a oblong (pronic) number + 1/4 having a half-integer value. The name "oblong" indicating they are analogous to polygonal numbers.
I'm not sure what you mean by "analogous to polygonal numbers." Oblong numbers map 1:1 to triangular numbers (= 2 times a triangular number) and triangular numbers are one kind of polygonal number, but Polygonal numbers in general?
It's true that the polygonal numbers can be constructed from the counting numbers + multiples of triangular numbers, but that involves first differences between polygonal numbers of equal index (e.g. the 5th square is 25 and 25 + 10, the fourth triangular number, = 35, the 5th Pentagonal number), not polygonal numbers themselves.
- AC
- AC
A pronic + 1 is a centered polygonal number. ∏(1/2 + √n) gives no information about ∏ itseft, it is trivial.
  • · Replies 24 ·
9K
