Proof of quadratic irrationals - stuck
aarciga
I have to show a proof that if a is odd, b is even, and c is even but not divisible by 4.
a,b,c are int coefficients
ax2 + bx + c = 0
has no rational solutions
all letters here are integers.
So i have,
a = 2d + 1
b = 2f
c = 2g, but c is not divisable by for so, c \neq 4h
so, g \neq 2h, or g is not even. g is odd
c = 2(2j + 1)
Im trying to show that the discriminant in the quadratic formula can't be a square, but I am having trouble showing that.
or that b2-4ac can't be a square number
\sqrt{4f^{2}-4(2d+1)(2(2j+1))}
(2d+1)(2j+1) will give some odd number 2k+1
\sqrt{4[f^{2}-2(2k+1)]}
2(2k+1) will give an even number 2m
\sqrt{4[f^{2}-2m]}
\sqrt{f^{2}-2m}^{2} can't = some square \frac{S^{2}}{2^{2}}
f^{2}-2m = \frac{S^{2}}{4}
After I show that it isn't a square, i can show that the square root of a non square is irrational. But I feel like i might be off base on this. It seems like the discrimininant certainly could be a perfect square.
it looks like I am trying to show that a perfect square can't equal a perfect square divided by 4. which is false. ( i.e. 16/4 = 4)
so, any ideas to point me in more proper direction, or to make a point on what i already have would be greatly appreciated.
Another way of thinking about it??
\sqrt{b^{2}-4ac}
\sqrt{(2f)^{2}-4(2d+1)(2(2j+1))}
2f is even, so (2f)2 is even
and 8(2d+1)(2j+1) is even x (odd x odd). (odd x odd) is odd so then even x odd = even
\sqrt{even number -even number}
even number - even number = even. = 2m
so i must show
\sqrt{2m} can't be rational, or
\sqrt{2m} \neq some rational number \frac{P}{Q}
and from here, I can prove \sqrt{2} is irrational.
and assuming \sqrt{m} is rational, an irrational time a rational can't be rational??
\sqrt{2}\sqrt{m} \neq \frac{P}{Q}
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
