B (Proof) Two right triangles are congruent.
The discussion centers on proving the congruence of two right triangles, ΔPQM and ΔP'Q'M', based on the equality of their corresponding legs. The first proof utilizes the Pythagorean theorem to establish that the lengths of the hypotenuses are equal, thus confirming congruence through a theorem from the referenced textbook. The second proof employs isometries, demonstrating that a translation and rotation can map one triangle onto the other, ultimately leading to the conclusion that the triangles are congruent. Participants discuss the validity of the proofs and the potential replacement of a segment in the second proof, with consensus that both approaches are sound. The conversation emphasizes the importance of understanding isometries in the context of triangle congruence.
vantroff
Hi, the question is from Serge Lang - Basic mathematics, Page 171 exercise 6.
Thing to prove:
Let ΔPQM and ΔP'Q'M' be right triangles whose right angles are at Q and Q', respectively. Assume that the corresponding legs have the same length:
d(P,Q)=d(P',Q')
d(Q,M)=d(Q',M')
Then the right triangles are congruent.
My first attempt by using the just the Pythagorean theorem.
d(Q,M)2 + d(P,Q)2 = d(P,M)2
d(Q,M)2 + d(P,Q)2
= d(Q',M')2 + d(P',Q')2 = d(P',M')2
It follows that:
d(P,M)2 = d(P',M')2
and
d(P,M) = d(P',M')
We conclude that the triangles are congruent by Theorem 10 in the book (page 168) which states the following:
Let ΔP,Q,M and ΔP',Q',M' be triangles whose corresponding sides have the equal length, that is
d(P,M)=d(P',M')
d(P,Q)=d(P',Q')
d(Q,M)=d(Q',M')
These triangles are congruent.
Second attempt by using isometries (not using Theorem 10 from the book).
There exist translation which maps Q on Q'. Hence it suffices to prove our assertion when Q=Q'. We now assume Q=Q'. Since d(Q,M)=d(Q,M') there exist rotation relative to Q which maps M on M'. This rotation leaves Q fixed.
This reduces the case to :
Q=Q'
M=M'
Now either P=P' or P≠P'. We assume P≠P'.
Let LQM be the line passing through point Q and M.
The segments P'Q and PQ are perpendicular to LQM. Also, d(Q,P')=d(Q,P).
⇒ Q lies on the perpendicular bisector of the segment PP'. The only perpendicular line to PP' which passes through Q is LQM. We conclude that LQM is the perpendicular bisector of PP' and that poins P,Q,P' are collinear and P is at the same distance from Q as P' but in the opposite direction.
There exist reflection through LQM which leaves LQM fixed and maps P on P'.
We found that there exist composite isometry F such that,
F(Q)=Q'
F(M)=M'
F(P)=P'
and given that the image of line segment PQ under isometry G is the line segment between G(P) and G(Q), we conclude the assertion proven.​
Can the red part be replaced by this blue part (or omitted)?
Angle ∠MQP=90° and ∠P'QM=90° ⇒ ∠ P'QP is 180° ⇒ P,Q,P' are collinear.
The second proof is more important to me because I'm at the Isometries part of the book. Is there something wrong with these proofs?
Thanks in advance for everyone who will spend time on this.
Mathematics news on Phys.org
Looks fine, both with red and blue. With the blue text, I would keep the last part of the red text about the same distance.
Likes vantroff
Just using the fact that my post is at the top...
Thanks for the fast answer!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
