Propagation of uncertainty from wavenumber to wavelength
jbar18
Hi,
This is just a quick question. If wavenumber is a variable with some standard deviation Δk, how do I propagate this spread when converting from wavenumber to wavelength? Is it just 2π/Δk or is it more complex than that?
Thanks
Its more complex than that! Think about it: with what you wrote, the worse your wavenumber measuring instrument, the better your knowledge of the wavelength?
Check out:
http://www.rit.edu/~w-uphysi/uncertainties/Uncertaintiespart2.html#muldiv
You can also get the same desult from a simple derivative:
\frac{d \lambda}{d k} = -\frac{2 \pi}{k^2} \Rightarrow \Delta \lambda = \frac{2\pi}{k^2} \Delta k
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Thread 'Detail of Diagonalization Lemma'
The following is more or less taken from page 6 of C. Smorynski's "Self-Reference and Modal Logic". (Springer, 1985) (I couldn't get raised brackets to indicate codification (Gödel numbering), so I use a box. The overline is assigning a name. The detail I would like clarification on is in the second step in the last line, where we have an m-overlined, and we substitute the expression for m. Are we saying that the name of a coded term is the same as the coded term? Thanks in advance.
