cianfa72
- 3,012
- 313
- TL;DR
- About the properties of angular momentum calculated w.r.t. a fixed point P in the rest frame of the system's center of mass (CoM).
A very basic question about the properties of angular momentum for a system of particles.
In a reference frame (inertial or otherwise) fix a point P and calculate the angular momentum ##\vec L_p## w.r.t. it. Then take the direction ##\vec a## and project ##\vec L_p## along it. Then the following result holds $$\frac {dL_a} {dt} = \tau_a$$ where ##L_a## and ##\tau_a## are the projection of the angular momentum ##\vec L_p## and the total external torque ##\vec \tau_p## about P on the ##\vec a## direction, respectively.
Next, pick the rest frame of the system's center of mass (CoM). It has the property that the angular momentum ##\vec L_p## calculated about any fixed point P in this frame returns the same result. Note that is a kinematic fact, therefore it holds regardless of whether the system's CoM rest frame is inertial or is not.
Of course, in the latter case, the contribution to the total external torque ##\vec \tau## abount point P includes the torque due to the inertial/fictitious forces that appear to "act" on the system's particles.
Did I understand it correctly ? Thanks.
