Can Proportional Variation be Deduced Algebraically from Given Equations?
Proportional variation among variables A, B, and C can be algebraically deduced from the equations A = kB and A = iC by recognizing that both k and i are functions of their respective constants. By keeping C constant in the first equation and B constant in the second, it is established that A is proportional to both B and C. This leads to the conclusion that A = jBC, where j represents a constant of proportionality. The relationship implies that if B and C are independent, then k must be proportional to C and i must be proportional to B. Thus, the algebraic deduction of A = jBC follows logically from the initial observations.
dx
Homework Helper
Consider the following situation :
There are three variables A, B and C. (and i,j,k are constants )
Keeping C constant, and varying the other two, you find that
A = kB ------(1)
Now, Keeping B constant, and varying the other two, you find that
A = iC ------(2)
I know that it follows from these two observations that
A = jBC
But I am not sure how we can algebraically deduce this from the equations (1) and (2).
We get A^2 = ikBC
Presumably, ik = \sqrt{j}BC
But how do we deduce this?
Mathematics news on Phys.org
You have
A = k(C) \times B = i(B) \times C
where k and i are functions of C and B, respectively. If B and C are independent variables then the only way k(C)B and i(B)C can be equal is if k is proportional to C and i is proportional to B. Therefore, A = jBC.
Thanks for the help.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
